Won't Idle When Cold
Old Sep 5, 2008 | 07:51 AM
Bob88vette's Avatar
Bob88vette
Default Won't Idle When Cold
My all stock '88 has just started to die when cold. Pull up to an intersection let off the gas and engine dies. It has no trouble starting right back up and starts perfectly from sitting cold.
After the oil and water heat up good I get a very nice running engine with a 700 rpm idle.
About 5 months ago I had all injectors replaced and fuel rails cleaned. This no idle problem just started a month ago so I don't THINK it's related to that repair.
Where should I start to troubleshoot?
I searched and found alot of idle discussions but none that matched my situation so my apologies if this is a dup.
Thanks as always for the education
Old Sep 5, 2008 | 10:54 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
My '85 was doing something similar, it would start right up but would die while idling or die when I put it in gear. This would happen until the temp got to about 130. Quite by accident I cured it by swapping MAF sensors. I'm not saying for you to go out and buy a new MAF but if you have a buddy with a good one swap it to your engine and see what happens. My engine threw no codes and the MAF was completely intact inside.
Old Sep 5, 2008 | 11:29 AM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
Have you been able to smell the exhaust when it dies (smell gas)?
Is it dieing because it is too rich or lean?
Does your year have an 'IAC' (Idle Air Control) mounted in/on the MAF?
If so, maybe the IAC has failed or its passageways are clogged or it just needs to be reset.
On our 94, there is a reset procedure for the IAC, presume if your year has an IAC, there is a reset procedure for yours too, so you could try it.
Old Sep 5, 2008 | 12:56 PM
Road Agent's Avatar
Road Agent
Old Sep 5, 2008 | 01:55 PM
MK 82's Avatar
MK 82
Originally Posted by Road Agent
You beat me to it. Someone isn't quite ready for prime time.
Old Sep 5, 2008 | 01:59 PM
MK 82's Avatar
MK 82
I would start by thoroughly cleaning the TB and the IAC with TB cleaner. Cheap and it probably could use it.
Old Sep 5, 2008 | 04:05 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
And the reset base idle and trim up the TB low/hi adjustments.
If that doesn't solve the problem, pull the connector to the cold start injector and note the effect if any.
To Won't Idle When Cold
