Transmission switch for failed Nox?
Old Sep 5, 2008 | 04:20 PM
blown87's Avatar
blown87
GA Events Coordinator
Default Transmission switch for failed Nox?
My car failed on Nox, everything is up to snuff, no egr problems, new convertor, etc.
When folks talk about a trans switch being the problem, exactly which switch are they talking about?
87 auto
I may be thinking of a EGR switch.
Thanks Greg
Old Sep 5, 2008 | 06:21 PM
engle1147's Avatar
engle1147
Excessive Oxides of Nitrogen (NOx):
High NOx can occur when there is excessive temperature in the combustion chamber or a damaged catalytic converter.
Check the following:
• Air Injection System
• Exhaust Gas Recirculation System (EGR)
• Combustion Chamber Deposits
• Oxygen Sensor
• Catalytic Converter
Diagnostics for NOx failures
OVERALL
·Check for causes of high combustion temperatures. Primary systems that affect NOx include:
-mixture control (lean)
-EGR
-ignition
·Check Catalytic Converter
1981-86
O2 sensor (The signal from the O2 Sensor provides a wealth of information on how the vehicle is running.)
EGR valve and EGR hose
Ignition timing and system (advanced timing and ignition components are some of the most common problems)
Vacuum lines (deterioration of vacuum lines, inlet manifold seals become more prevalent causes with age)
Catalytic converter
Primary feedback sensor failure, including oxygen sensor, MAP/MAF, TPS, RPM, and CTS sensors
1987-95
Use OBD, if available
O2 sensor
Primary feedback sensor failure including, oxygen sensor, MAP/MAF, TPS, RPM, and CTS sensors
Vacuum lines
Catalytic converter
Old Sep 5, 2008 | 10:55 PM
blown87's Avatar
blown87
It is a 87, fresh rebuild on heads, all of the rubber hose parts around the intake have been replaced, correct factory egr valve and temp sensor 1 year old.
We are getting a good swing on the O2 sensor and the wide band shows 14.5 to one at cruise.
All of the passage ways for the EGR are clean, very clean.
it has a new direct replacment cat on it.
Ignition timing is at 5 BTDC.
the coolant temp sensor is less than six months old.
With it hooked up to a Snap-On Modis, the CTS, O2, tps and mass air flow all look very good and they graph out with no glitches.
We have done this in "generic" so we know we are getting actual values.
I had this problem last year and had to hook a water bottle up and retard the ignition advance to make it pass.
It has set no codes in the last year, other than induced codes.
A couple of things make me wonder, the CO and the HC both are at zero, which indicates a lean mixture and that leads to higher cumbustion chamber temps and higher Nox, but the wide band does not show a lean mixture.
My guess is that the new cat is really doing its job of cleaning up CO and HC's.
The Nox is higher after this last valve job, which makes three head jobs on this motor, I know for sure that the head has been cut three times which along with a .60 over bore will raise Cr.
Other than the blower this motor is stock rebuild and has passed for several years.
I am a pro mechanic, just not so much on Chevys of this vintage, if it was made in Europe I might have a better handle on it.
• Oxygen Sensor
OVERALL
-EGR
-ignition
1981-86
Catalytic converter
1987-95
O2 sensor
Vacuum lines
Catalytic converter
To Transmission switch for failed Nox?
