Recommended crate engine for 95 LT1??
Old Sep 6, 2008 | 06:18 PM
kjgcsmith's Avatar
kjgcsmith
Default Recommended crate engine for 95 LT1??
What would you suggest as a good GM Crate engine to replace my 95 LT1???
I want something that is a direct bolt in and NO OPTISPARK......
Does not need to be high performance...just a solid engine.
thanks
Old Sep 6, 2008 | 06:27 PM
BlackC6LS3's Avatar
BlackC6LS3
GM does not make a crate LTX motor. There are a few good builders out there. I'd stay away from Golen.
Old Sep 6, 2008 | 06:31 PM
Pete K's Avatar
Pete K
Old Sep 6, 2008 | 06:40 PM
kjgcsmith's Avatar
kjgcsmith
so there are no crate engines out there with electronic sparks that are a straight drop-in for the 95 vette??? I have nad nothing but problems with optisparks and want to get rid of the opti.
Old Sep 6, 2008 | 08:00 PM
lcvette's Avatar
lcvette
Accel DFI with Dual cynch Distributor but you have alot of emissions stuff to be rid of to make the dizzy fit.
Chris
Old Sep 6, 2008 | 08:20 PM
66grandsport's Avatar
66grandsport
Any Golen feedback please?
Old Sep 6, 2008 | 09:35 PM
kjgcsmith's Avatar
kjgcsmith
Chris, will the car still pass state emission tests?
Old Sep 6, 2008 | 11:12 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Unless you run the opti, nothing will be a direct bolt-in.
Old Sep 6, 2008 | 11:15 PM
lcvette's Avatar
lcvette
in texas I don't know. My guess is that it would not. because the EGR valve would need to be removed... although the 1996 corvette did not come with an EGR valve so its a toss up.. you would have to look into it in your state!
Chris
Old Sep 6, 2008 | 11:39 PM
grinditout's Avatar
grinditout
Buy a Dynaspark.
Old Sep 7, 2008 | 01:46 AM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
http://paceperformance.com/index.asp...S&Category=130
Old Sep 7, 2008 | 02:35 AM
Lrod's Avatar
Lrod
Originally Posted by grinditout
Buy a Dynaspark.
Same here, 3 yrs ago
Old Sep 7, 2008 | 02:40 AM
cv67's Avatar
cv67
St. Jude Donor '05
Doesnt TPIS make a miniram for the LT where you can use a distributor?
Old Sep 7, 2008 | 07:53 AM
MK 82's Avatar
MK 82
Chris
Put in an LT4. No EGR!
To Recommended crate engine for 95 LT1??
