knock sensor
Old Sep 7, 2008 | 04:32 AM
vettlag's Avatar
vettlag
Default knock sensor
i'm getting different responses from people with the idea that a gear drive might work with knock sensors and that it wont work so i am going to put the question to the test i'm puting one in my 85 and i will find out my knock sensor last year was not conected and replaced it don't know how long it was disconected anyhow the therory of plumers tape on the threads of the knock sensor is what i'm try'n like i said i have to know. also i was wondering is there a way to reprogram the chip to bye pass sensor any thoughts . thanks
Old Sep 7, 2008 | 07:46 AM
rodj's Avatar
rodj
Unsure on your year but later ECM programming has setting for knock sensor and the amount / time spark is retarded when knock registered.
A resistor can be used in place of the KC so the ECM thinks it is still there and functioning.
Old Sep 7, 2008 | 08:46 AM
MK 82's Avatar
MK 82
A knock sensor generates an AC voltage. Not sure how a resistor would simulate that.
Old Sep 7, 2008 | 11:27 AM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
A knock sensor does not "generate " any AC voltage. You might consider it to condition DC voltage.A knock sensor returns a steady DC baseline voltage to the ECM. When knock occurs the resistance in the sensor changes causing that DC voltage level to spike.Just because a voltage changes does not make it AC voltage. That can only be done with a transformer. If you use an Oscope to look at the KS you are looking at alternating DC voltage.
That being said any type of thread sealant/tape will decrease the sensitivity of the sensor to answer the OP's question. A resistor in place of the KS will only fool the ECM into thinking the KS is present and do nothing to adjust timing if there is knock. Some people who wish to disable the KS use one so they do not get a SES light.
Old Sep 7, 2008 | 04:26 PM
vettlag's Avatar
vettlag
well we will see what happens order a summit gear drive should have done by fri maybe sooner.
Old Sep 7, 2008 | 06:08 PM
MK 82's Avatar
MK 82
VERBATIM from my 96 FSM page 6-458
"The Knock Sensors produce an AC voltage that is sent to the KS module. The amount of AC voltage is proportional to the amount of Knock.
An operating engine produces a normal amount of engine mechanical vibration (noise). The knock sensors will produce an AC voltage signal from this noise."
You are talking out of your **** orifice again.
Old Sep 7, 2008 | 06:19 PM
MK 82's Avatar
MK 82
A transformer steps AC voltage up or down. It does not change from or to DC or AC.
You may claim to be an electrician but I hold a BS in Electrical Engineering.
Stick to pulling wire.
Old Sep 7, 2008 | 06:54 PM
Redeasysport
You may hold a BS but that doesn't make you right There is no AC in a corvette period.That of course excludes the primary side of the alternator.
As far as a AC to DC transformer(convertor) goes
http://parts.digikey.com/1/parts-cat...l-transformers
http://www.amazingoutlet.com/1amp-12...er-supply.html
I could post links all day. In reality it may be a voltage rectifier but many layman refer to it as a transformer.But I am sure you knew that. Keep using your BS degree.
Old Sep 7, 2008 | 07:09 PM
Redeasysport
Well in reality if your degree is true you know AC (alternating current)refers to both the negative and positive parts of a sine wave. The is no negative voltage in a Corvette what you refer to is a conditioned DC voltage going from a baseline voltage to a higher voltage and back down to the baseline voltage. It is not current that is alternating it is voltage based on varying resistance. The current remains the same.
And just where is this KS module located?I am sure you know the difference between produce and generate correct?
This would not be the first time the FSM used the wrong terms. If it read alternating voltage instead of current I would agree.
Old Sep 7, 2008 | 07:20 PM
MK 82's Avatar
MK 82
As usual you spout crap and then tap dance around it. Take it up with the folks who designed the car and wrote the FSM. The AC voltage comes from the knock sensor. Virtually all one wire knock sensors produce an AC voltage. It is a sine wave of varying frequency and intensity.
Old Sep 7, 2008 | 07:22 PM
MK 82's Avatar
MK 82
More tap dancing. You used the word transformer. Spin it how you will.
How was your unpaid vacation?
Old Sep 7, 2008 | 08:05 PM
Redeasysport
Talk about tap dancing what does AC mean? It IS NOT a sine wave by the way. If anything it is a sawtooth wave.Here take a look
http://www.wellsmfgcorp.com/pdf/counterp_v4_i4_2000.pdf
I am not tap dancing I am telling you and the world the FSM has a term wrong in it big deal it is not the first time it has been pointed out to be in error. It isn't the bible.No KS produces an AC voltage period. It produces a DC wave signal if you have the degree you say you should be able to explain the difference.
It is produced by a piezoelectric crystal can you tell me how? No tap dancing now show me your degree.
Now back to the OP with a 1 wire KS the block is ground so using anything that will interfere with it contacting the block will cause issues.
http://www.youtube.com/watch?v=0xI94ZDF54Y
Old Sep 7, 2008 | 08:54 PM
vettlag's Avatar
vettlag
so again my theroy of the plumed tape may work and if some one has another idea would like to hear thanks
Old Sep 7, 2008 | 09:02 PM
Redeasysport
If you are saying you want to cause the knock sensor not to work and set a fault that is what teflon tape may do. Exactly what are you aiming for and why?
The ECM will check the KS on start up and if it isn't working it will set a fault.
Old Sep 7, 2008 | 09:10 PM
formul89's Avatar
formul89
You have an FSM. You rule at C4 Tech/Performance.
Old Sep 7, 2008 | 09:16 PM
Redeasysport
If you are trying to bypass it
http://forums.corvetteforum.com/show...s+sensor+knock
rodj's Avatar
rodj
And regardless of the AC/DC sinewave flux generastor effect ,
the correct resistor will trick the ECM into thinking the KC is present and working correctly.
You just need to have a ear for engine pinging like the old days before electonics and KC's.
I only have a degree in BS though.
To knock sensor
Old Sep 7, 2008 | 09:17 PM
HeeHaw89's Avatar
HeeHaw89
Old Sep 7, 2008 | 09:18 PM
Redeasysport
Old Sep 7, 2008 | 09:33 PM
engle1147's Avatar
engle1147
Vettlag,
Gear drives in a knock sensor equiped vehicle is not recommended by the manufacturer for a reason....but you can give it a shot if you must.
So good luck with that... let us know how it turns out.
Guys,
The knock sensor is a voltage generator all by itself....hense the 1 wire.
To better understand the whole process here is a link:
http://www.autoshop101.com/forms/h38.pdf
