Crank Trigger
Old Sep 8, 2008 | 10:19 AM
MK 82's Avatar
MK 82
Default Crank Trigger
Anyone ever put one of these on an LTX?
Old Sep 8, 2008 | 03:42 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
You would need to put it on a DFI sytem or equivalent aftermarket computer for the signal to be interpreted correctly.
I have one on my "l98" setup that feeds into a Accel DFI computer.
The crank trigger is TONS more stable at high RPM and is dead nuts accurate. No vibration from the cam to crank to contend with or timing chain slop.
Old Sep 9, 2008 | 09:16 AM
Tom Piper's Avatar
Tom Piper
The Electromotive Opti-Eliminator was a crank trigger system for the LT1.
http://members.aol.com/InjuneerZZ/Emotive.htm
It was designed by J.C. Hyde, the same engineer that developed the Delteq system.
The Opti-Eliminator was OK on a batch fire system, but didn't work on sequential fuel injection that started in '94.
Edit: The Opti-Eliminator had no camshaft position sensor.
Tom Piper
Old Sep 9, 2008 | 09:32 AM
formul89's Avatar
formul89
Go buy an FSM and look it up.
To Crank Trigger
