Engine Combo Opinions Please, My first build.
On the cam, I want a fairly aggressive, just to be streetable with decent vacum. I've read a lot of storys with too much cam, and don't want to end up that way.
If I stay with flat tappet cam, Does anyone have a cam in mind that they have a good experience with?
The biggest drawback to the Brodix IKs is that they only come in straight plug configs. They are a good head for the money.
Under $1000, there's patriot.
https://www.patriot-performance.com/...&cat=40&page=1
Go to the roller cam, there's no reason not to. A set of roller lifters is $120 from GM performance. The cam is no more expensive than the one your looking at.
"best heads" are the ones that match your cam, intake, and exhaust within your budget. That's when the combination comes together.
Since your going flat tappet with pretty low lift, i aggree with jsup on this one. YOu could get away with cheaper heads that should support your goals and that cam better. However i still feel AFR's even with less than optimal lift are not a bad choice and since you plan on larger power down the road i wouldnt hestitate to get them
heres a problem tho. AFR factory springs are setup with 135lbs on the seat, designed for roller cams. Thats alittle high for a flat tappet and your gonna wear the lobes/lifters down. So when you get them , take the factory AFR shims off the head and then reinstall the springs for lower spring pressure.
I cant remember what the factory installed height was, i think it was 1.76" or close to that which i think will give more like 140lbs seat pressure. AFR had .015" and i think .030" shims on those heads. I'd have to check my build notes as i wrote down what i shimmed my springs to for my roller to get more pressure and i think i wrote down the factory AFR specs. Either way i'd advise to check out the installed height and shim to lessen the pressure on that cam.
Now that i think about it, the seat pressure may not be your only problem. Thats a double spring so the open pressure will be around 350 i think is which is also way high for a flat tappet.
AFR isnt really a good head choice out the box for flat tappets due to the springs installed but you can always go buy a set of comp 981's for less than 100 bucks and sell the AFR 8017 springs as they are GREAT springs that fit stock L98 heads and LT1 heads so anyone looking for a cam swap for their LT1/L98 those springs would be a wise choice. You'd get your money back easily.
That cam isnt bad but i think it will be done before 6000 rpm being short of your goal. you could look into one step bigger for that over 6000 rpm range but watch the overlap. Smoother idle will be with less overlap. This is why i like roller cams. you can get lift and less overlap to make a smooth car but make nasty power still. But with your lower compression at 9.7 to one or so, that bigger cam will make it abit lazy on the low end. Still enough to be fun but not as much as the smaller cam. when in doubt error on the small side.
I'd go ahead and say that cam you have in mind isnt that bad. Run 1.6 rockers tho to get the lift up to make the AFR heads happy.
Keep in mind that 383 down the road. the more parts you can have now to make it happy for the 383 later the better. If you plan to reuse that block, convert it to hyd roller cam now and be much happier later with the AFR's.
Else keep your AFR springs and swap them in later when you get a 383 block but make sure its a roller cam block and run a roller cam down the road. It will be very much worth it
