Dash lighting dim?
Old Jan 5, 2002 | 06:38 PM
tsquare's Avatar
tsquare
Default Photosensitive Lens Going south?
During the the day my dash dosen't seem to illuminate as bright as it once did.And at night it only gets really bright if I'm under an overpass or in a lighted parking lot.Is there any diagnostic test I can do to see if the Photo lens is going bad.Any sugggestions appreciated
[Modified by tsquare, 3:00 PM 1/5/2002]
Old Jan 5, 2002 | 07:34 PM
vader86's Avatar
vader86
Default Re: Photosensitive Lens Going south? (tsquare)
have you replaced your bulbs before? That might be a good idea if you havent. Put your thumb over the cell and see if the dash dims, also make sure your headlight **** is turned to full brightness (i sometimes forget myself)
Old Jan 5, 2002 | 09:07 PM
tsquare's Avatar
tsquare
Default Re: Photosensitive Lens Going south? (vader86)
I have replaced all the bulbs.I haven't tried placeing my finger over the lens yet.If the lens is bad is there a fix for it?
Old Jan 5, 2002 | 10:46 PM
GlockLT4's Avatar
GlockLT4
I hit the dim variable resistor switch all the time on accident when I turn the headlights on and off...
Old Jan 5, 2002 | 11:05 PM
tsquare's Avatar
tsquare
Its not the dimmer either.I might just pull the gauge package out again and make sure all the wire connections are snug.Otherwise I gues I'll just live with it.
Old Jan 5, 2002 | 11:43 PM
vader86's Avatar
vader86
well there isnt really a fix for it other than replacing the unit, but as long as you can see the numbers during the day clearly then id just live with it
To Dash lighting dim?
