True or False
Old Sep 10, 2008 | 03:39 PM
simple green's Avatar
simple green
Default True or False
I'm just trying to understand a couple concepts... lemme know if I'm on the right track.
When I do a PCM read with Tunercat, on a stock 94, the values I'm looking at are all the factory set default values for the PCM to use?
When I do a datalog with datamaster, the LTerm counts are what the PCM has learned, beyond the stock PCM settings, from the knock, O2, temp, etc sensors and therefor has adjusted the average fuel curve based on how I drive, grade of fuel, atmospheric pressure etc..?
STerm counts are immediate actions to fuel curve from sensor feedback?
Datamaster O2 mv's directly affect sterm counts?
It's ok for Sterm counts to bounce back and forth between lean and rich by how many values?
What is the fuel trim cell?
Why are a many knock counts ok before the PCM desides to retard timing?
Thanks Eric
Old Sep 15, 2008 | 03:00 PM
simple green
ttt
Old Sep 16, 2008 | 03:30 AM
convas's Avatar
convas
Check this thread MSEVEN has some good links.
http://forums.corvetteforum.com/show....php?t=2133409
Old Sep 16, 2008 | 08:49 AM
VenkmanP's Avatar
VenkmanP
Do a google search on LT1 PCM tuning, and also just PCM (or ECM) tuning. There are several good web pages out there that describe how it all works.
Table values, yes.
Values in calculators, no. (Like the speedometer calculator.) Those will show the tunercat defaults.
Old Sep 16, 2008 | 03:22 PM
simple green
sweet, thanks guys... I'll be busy reading for a while
To True or False
