Underdrive Pullies?
Old Jan 5, 2002 | 08:39 PM
Too Slow '90's Avatar
Too Slow '90
Default Underdrive Pullies?
Do underdrive pullies give any gains? Are they hard on the engine?(mine has 90K) If they are a decent mod who makes a good set? How hard are they to install and how expensive? :chevy
Old Jan 5, 2002 | 09:12 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Underdrive Pullies? (Too Slow '90)
With only the underdrive crank pulley installed I noticed the engine revs up faster but saw no increase in trap speed due to other issues at the time. With accessories on at night at idle (700rpm) I only see about 11.5 Vdc. You've got mail on the HP to expect.
It's actually easier on the engine with less parasitic drag.
March makes a 3-piece pulley set, though I've not yet installed the alt overdrive pulley. Cost was about $125.
The crank pulley is easy to install; the alt pulley requires an impact wrench. You will also require a shorter serpentine belt.
Old Jan 5, 2002 | 11:57 PM
Vic'89's Avatar
Vic'89
The pullies are not hard on the motor at all.
The crank underdrive pulley will help your ET's ever so slightly.
The bad point is that you will have a lower battary voltage at idle.
Vic
Old Jan 6, 2002 | 09:16 AM
lowflyer's Avatar
lowflyer
Cruise-In I Veteran
Default Re: Underdrive Pullies? (Vic'89)
Vic
Thats the same problem I had too. At night , foot on the brakes, lights on, a/c on, radio on, and turn signals or wipers on, the voltage would drop to 11.5v. I had to keep slight pressure on the gas pedal to keep the low voltage light from coming on. I guess I could've bumped up the idle a bit, but it would only do it when I had a big load on the electrical system, so I lived with it for a few years. (yeah, I'm lazy...)
[Modified by lowflyer, 1:14 PM 1/6/2002]
Old Jan 6, 2002 | 05:43 PM
SLOWBUSA's Avatar
SLOWBUSA
Default Re: Underdrive Pullies? (lowflyer)
:yesnod:
To Underdrive Pullies?
