New Opti, rough idle and pinging when started
Old Sep 19, 2008 | 11:40 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Originally Posted by Roger420
Sounds like his problem. Quit wasting your time and money and get a MSD opti!
Why so it can fail on him? Better do a search they are failing at an impressive rate. There is nothing wrong with the OEM opti that he got from thepartsladi.They are affiliated with a major corvette supplier and a dealership.
As I said already your car is running you can wait for someone with a crystal ball or you can get a scan posted and look at what the engine is doing.
Old Sep 19, 2008 | 11:55 PM
Ed Ramberger's Avatar
Ed Ramberger
When you replaced it and you noticed that the rotor was visibly off upon replacement, did you compare the 2 Opti units and make sure that the new one placed the rotor at the same position as the original one if you referenced both the drives in the same position?
Old Sep 19, 2008 | 11:59 PM
jwigg's Avatar
jwigg
I just put one on my 96 from the parts ladi and it works fine.
What were your simptoms before replacing the opti?
Old Sep 20, 2008 | 12:18 AM
lltrevino's Avatar
lltrevino
bought numerous products from that seller, and all top notch GM replacements. That seller sells first rate products, has been my experience.
Old Sep 20, 2008 | 06:51 AM
topspin's Avatar
topspin
maybe the gas.. Pinging. Sounds like it maybe fuel related.
