A/C problem blows cold then will go hot for a few seconds
Old Sep 11, 2008 | 10:22 PM
vettes4fun's Avatar
vettes4fun
Default A/C problem blows cold then will go hot for a few seconds
I have replaced the control head, programmer, blend door motor, inside and outside temp sensors plus the sun sensor. I have check the blend door and it's ok. I can watch the blend door and it will move back an forth every 15 seconds or so. I have tried to unhook the battery and this does not help.
Old Sep 12, 2008 | 12:11 PM
Yellow2015's Avatar
Yellow2015
Has the refrigeration system been worked on lately? Freeon added? It could be anything from the metering device freezing to having non condensibles in the system.
Old Sep 12, 2008 | 12:44 PM
engle1147's Avatar
engle1147
Sounds like the compressor is short cycling......probably too much (over pressure) or not enough (under pressure) freon in the system.
To A/C problem blows cold then will go hot for a few seconds
