L98 Redline
Old Sep 13, 2008 | 07:36 PM
ride250s's Avatar
ride250s
Default L98 Redline
I have an '87 L98, whats the redline limit? I guess I cant really tell from the digital dash.
Old Sep 13, 2008 | 07:39 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I shift at 5000 RPM. The car falls on its face around there.
Old Sep 13, 2008 | 08:22 PM
hurricanejames's Avatar
hurricanejames
Five grand would be the upper end for these motors, assuming you mean 'stock'. I believe 4800 rpm is redline. Honestly, it's been my experience that you're wasting your time revving the snot out of it...I find mine runs best when I let my L98 do what it does best: Put out pretty respectable bottom-end torque, shift early (42-4300 rpm), and let it ride that torque curve. You wanna rev it? Move on to an LT1.
Old Sep 13, 2008 | 09:26 PM
ride250s's Avatar
ride250s
No, I was just curious. Its my first vette and I have only driven it twice... Just tryin to feel it out and get a sence for it. I just wanted to make sure I didn't over rev it so I was making sure.
Old Sep 14, 2008 | 01:43 AM
rodj's Avatar
rodj
No chance of that , has built in rev limiter;
called TPI intake
I'm with the others , best times at track shifting at 4500 Will rev higher but you will be slowing down.
Old Sep 14, 2008 | 02:20 AM
ride250s's Avatar
ride250s
roger that, thanks guys!
Old Sep 14, 2008 | 08:56 AM
engle1147's Avatar
engle1147
called TPI intake
Old Sep 14, 2008 | 09:11 AM
mr.beachcomber's Avatar
mr.beachcomber
Default ECM Programmed Redline Is 5800 RPM
The ECM is programmed to cut off fuel at 5800 RPM, but you're well past peak HP at that point as the other posts have explained. I'd stick with the previously recommend shifts points between 4500-4800 RPM to keep your Vette in it's best torque/HP band. Have fun!
Old Sep 14, 2008 | 10:14 AM
Iroc57's Avatar
Iroc57
called TPI intake
That seems to be the best on stock TPI motors
Old Sep 15, 2008 | 12:22 PM
Kubs's Avatar
Kubs
That cant be. I have revved mine to 6-6500 RPM before without any fuel cutoff. This wasnt for shifting it was in between corners in an autocross where shifting wasnt possible.
Old Sep 15, 2008 | 01:07 PM
Aardwolf's Avatar
Aardwolf
From what I remember the L98 is 10,000 RPM cut out, the LT1 computer is programed at a different RPM.
Old Sep 15, 2008 | 01:23 PM
Demonic85's Avatar
Demonic85
its 10K, which makes no sense. I've hit 5800 with mine and it definitely falls off after 5K. I also shift at 4500
Old Sep 15, 2008 | 01:42 PM
ride250s's Avatar
ride250s
Damn you think they would have made it lower than 10K... that sounds like a Dangerous number!
Old Sep 15, 2008 | 02:06 PM
Aardwolf's Avatar
Aardwolf
It is, I'd be curious why they did that. I have a much lower number editted into mine.
Old Sep 15, 2008 | 02:36 PM
Bad Karma's Avatar
Bad Karma
And you'll be floating the valves long before that. I've had mine float at the end of a straight doing autocross. One of the guys with an '89 changes his springs every couple of years because of float and beating on them for autocross.
Old Sep 15, 2008 | 02:40 PM
cv67's Avatar
cv67
St. Jude Donor '05
Engineers knew it would never rev high enough under load to hurt itself so why bother (bean counting) is my guess.
Old Sep 15, 2008 | 09:56 PM
daytonaer's Avatar
daytonaer
But its still there, just at 10k.
I let a buddy take my tpi out for a spin, he came back revving the **** out of it (clutch in). I saw every light on the digital tach light up and cringed waiting for some valve train damage, but stupid abuse after 100k and it still runs great. I wished I had set the limiter to 6500 on that one, he would have hit it.
To L98 Redline
Old Sep 16, 2008 | 07:41 PM
BlackC6LS3's Avatar
BlackC6LS3
I've over-revved my 88GTA with the 305 TPI 5spd to around 6500rpm on downshifts.
Old Sep 17, 2008 | 10:50 AM
mr.beachcomber
Default My Bad! I Quoted the Redline for an LT1, Not the L98
You're correct. The L98 has a ridiculously high redline fuel cutoff of 10,031 RPM while the LT1 has a redline fuel cut off of 5850 RPM. :o
I'm sure that there's a excellent story of why the L98 has such a high fuel cutoff programmed into the its prom. Maybe it was for the SCCA Corvette Challenge series or other such racing? Surely there was a logical reason!
Old Sep 17, 2008 | 12:21 PM
ride250s's Avatar
ride250s
Those damn crazy GM engineers...
