Dyno readings question
Old Sep 13, 2008 | 09:24 PM
black_89_vette's Avatar
black_89_vette
Default Dyno readings question
Say an engine put out numbers, but the readings were 1000 RPM off, what would change about the hp numbers?
Since hp is derived from torque calculations, if it were reading peak tq at 3200 rpm and it should have read 4200 rpm, would this change the number it gave for hp?
Thing is a friends DIY dyno gave numbers on a friends car that said 456 tq @ 3200 and 320 hp @ 4000 or close to it.
Since we believe the dyno numbers to be off by 1000 rpm, would it change the 320 hp number at all since the calculations would be 1000 rpm off?
Turbo car.
Old Sep 13, 2008 | 10:38 PM
Zix's Avatar
Zix
Dynos read spark right from the plug-wires usually I think, so even if the tach in the car is off the dyno should still be correct.
EDIT: what's a DIY dyno?
Old Sep 13, 2008 | 11:07 PM
black_89_vette
A Do it yourself dyno. Basically it's not a dynojet or mustang dyno. It's one that the guy bought and assembled.
Old Sep 14, 2008 | 12:17 AM
Zix's Avatar
Zix
Where does it read the RPM from?
Old Sep 14, 2008 | 03:17 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Of course, since HP is simply an mathematical entity calculated from torque & RPM.
Old Sep 14, 2008 | 06:25 AM
black_89_vette
That's what I figured Jim. The hp numbers seemed low, it's a tune in progress at the moment. But since hp is just a mathematical calculation from tq, I wonder if you could somehow extrapolate what the hp numbers would be.
Old Sep 15, 2008 | 03:59 AM
BlackHarleyMan's Avatar
BlackHarleyMan
that's what i figured jim. The hp numbers seemed low, it's a tune in progress at the moment. But since hp is just a mathematical calculation from tq, i wonder if you could somehow extrapolate what the hp numbers would be.
hp=tq*(rpm/5252)
Old Sep 15, 2008 | 07:34 AM
StealthLT4's Avatar
StealthLT4
So look at what it read the Torque as at "4,000rpm", and perform the above calculation on that value, using 5,000rpm in the calculation.
To Dyno readings question
