1989 C4 Brake Rotor Thickness
Old Sep 16, 2008 | 02:35 PM
LT1 Rocker's Avatar
LT1 Rocker
Default 1989 C4 Brake Rotor Thickness
Does anyone have a clue what the acceptable thickness range is for rotors on an 89 Vette with standard suspension and brakes?
Thanks much!
Old Sep 16, 2008 | 04:19 PM
Aardwolf's Avatar
Aardwolf
The NAPA online site lists a spec. that may match your rotor or may not. The discard thickness is usually stamped in the back of the hat.
Old Sep 17, 2008 | 01:02 AM
Sam Lam's Avatar
Sam Lam
with Aardwolf as I gave away a set of used rotors off a 89 model and recall seeing the min thickness cast into the rotor.
Old Sep 17, 2008 | 02:53 AM
rodj's Avatar
rodj
I have 19mm on the std and 26.5mm on the J55 13"
Old Sep 17, 2008 | 12:47 PM
LT1 Rocker's Avatar
LT1 Rocker
Default Rotor Thickness
Thanks for the helpful info.
I will put it to immediate use.
Gary
Old Sep 20, 2008 | 06:45 PM
djoksch's Avatar
djoksch
For $15 more, I just bought new rotors
To 1989 C4 Brake Rotor Thickness
