benchracing a L98 - de-stroke it?
Old Sep 16, 2008 | 03:15 PM
John-in-Dallas's Avatar
John-in-Dallas
Default benchracing a L98 - de-stroke it?
I had a thought about changing the character of a L98 to a more high revving (fun?) character without changing the TPI, heads, etc.
I know the common wisdom (widely practiced here) that there's no substitute for cubic inches.....but what if one were to de-stroke an L98 to 302 CID (3 inch stroke) in order to make all of the breathing characteristics of the stock intake, cam, heads, and exhaust seem bigger for the displacement? Would that move the power band up the rev range, potentially adding horsepower while giving up low end torque?
A cam change might be in order, but would the TPI still be such a big limiter? I know the heads and 1.94 inch valves are good for 6,000 rpm on a 350 from an old ZZ3 that I had.
This comes from reading this forum too much... ;>]]
Old Sep 16, 2008 | 03:51 PM
pologreen1's Avatar
pologreen1
why do all that just put an lt1 intake or a mini ram an it then unless you want to be different! or take a 305 and make it a high reving motor!
Old Sep 16, 2008 | 04:07 PM
cv67's Avatar
cv67
St. Jude Donor '05
It would be fun to do a 302..Someone in here did a 327 that ran pretty well through a TPI, cant remember if the intake was modded or not.
Old Sep 16, 2008 | 04:35 PM
redrose's Avatar
redrose
Default the wall
305's w/ tpi run up against "the wall" at 5k...a 302 will probly do the same with tpi...but a 302, with it's "over-square" bore/stroke, fed by an lt1 intake, could be "interesting"...but gonna need to address the knock sensor vs solid lifters pita (again) to get to the 7k rpm that the 302 shines at...a scattershield is mandatory, even on the street.
bjankuski's Avatar
bjankuski
You might be able to make power a little higher then the 350 but the real problem with the TPI is the length of the runners. The runners are designed (wave tuning) to provide a power band that peaks at about 4500 RPM. If you change the CI of the engine the runners length did not change so the power band remains the same. The 302 may rev slightly higher but it will still peak near 4500 RPM and you will loose torque and HP when compared to the 350.
Old Sep 16, 2008 | 05:17 PM
formul89's Avatar
formul89
The long tube runner design is incredibly long from TB to cylinder. This design will hit a wall at 4,800 if stock, maybe 5,500 if replaced with larger parts.
My old '89 Formula 350 made 239 RWHP and 344 RWTQ. The dyno sheets showed a cliff for HP after 4,900 with the set up I had. The HP curve was almost flat while the TQ curve never stopped climbing.
At the track, it would be a couple cars ahead of LS1 cars at 1/2 - 3/4 track. After that, they would blow past like I was standing still and trapped way higher.
Old Sep 16, 2008 | 08:11 PM
Churchkey's Avatar
Churchkey
If your willing to change the crank to a 302 you will also need pistons. Any aftermarket pistons for a 302 are all high compression & even higher compression when used with 89 Vette heads as the combustion chambers are only 55 cc.
I am in the process of building a 302 with 89 Vette heads & a tpi for my 57 Chevy project.
here's how I made it work without having pistons custom made.
69 302 large main journal crank to fit a 350 block with a stock deck height of 9.030
Keith Black low compression pistons for a 350 with a 13cc dish.
Eagle 6" H beam rods.
Machine .030 off the piston top. This assembly = 0 (zero) deck height.
Compression ratio figures out to just under 10 to 1
Am not building a screamer, just want a crispy little motor to putt around with.
Old Sep 16, 2008 | 11:01 PM
pr0zac's Avatar
pr0zac
i don't see how putting a shorter stroke crank in an L98 would you have an issue with solid lifters and knock sensors?
Old Sep 16, 2008 | 11:09 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
The 302s in the late 60s were mean engines. Could be fun...
Old Sep 17, 2008 | 12:20 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
This idea makes some sense. When you put larger-bored TPIs on motors, the power bands do move up -- w/o much low-end loss. When they put a FIRST intake on a stock 350, there really wasn't any low-end loss. (But, the gains weren't that great either. I think that was due to the need for better-flowing heads.**)
If you do the math, I think a 302 would still benefit from a head that would flow at least 210cfm (maybe as much as 240cfm). Stock 113's can't do that. If you de-stroke, port 113 heads and install a bigger cam, you're idea should produce great power for a 302. Power would still roll-off between 5000 and 5300 rpms but under that WOOHOO!
If you want higher revs, don't say TPI and hi-revs in the same sentence.
gp
** TPI flows 195 cfm. 113's flow less than that w/stock cam.
Old Sep 17, 2008 | 01:05 AM
Aurora40's Avatar
Aurora40
FWIW, GM made a 305 with TPI. It made less power and less torque than the L98, though not much less power.
Old Sep 17, 2008 | 02:21 AM
rodj's Avatar
rodj
Correction;
GM made the TPI FOR THE 305 in the first place because they were going to drop the 350 .
They then cheaped out and put the 305 intake on the 350.
Old Sep 17, 2008 | 09:02 AM
formul89's Avatar
formul89
Originally Posted by rodj
Correction;
They actually designed the TPI for trucks because of the low end torque capabilities. It looked kinda cool, so they stuck it on the Y & F body motors.
It is sized right for a 305 but a bit too small for the L98.
Old Sep 17, 2008 | 11:40 AM
redrose's Avatar
redrose
the short-arm engine must be wound higher to benefit from its reduced stroke vs the 3.48" L98 stroke engine... hydraulic lifters won't suffice due to lifter pump-up at abt 6k rpm and solid tappets must be substituted...efi needs k/s to realize its potential (excessively "rich" fuel/air mix reduces engine output), but k/s has great difficulty in "hearing" normal solid lifter lash take-up "noise" as detonation, retarding spark (per ecm program, crucial to prevent piston meltdown) with attending large power reduction.
Old Sep 17, 2008 | 12:44 PM
1989TransAm's Avatar
1989TransAm
I think it is a very interesting idea. If I was to do it I would use the AS&M runners and the Edelbrock TPI intake manifold. Have the L98 heads ported and 2.02 intake valves installed. Maybe a cam on the order of 218/224.
Regarding the headers I don't think you want to go big maybe something on the order of 1.5" to 1.625". You would want a light weight valve train in order to spin it into the 7000rpm range.
Myself I would look into maybe the Dart Iron Eagle heads if you want to stay with iron heads. With aluminum it opens up some more possibilities.
Old Sep 17, 2008 | 01:22 PM
John-in-Dallas
This sounds like a cool little engine Churchkey. It looks like you were way ahead of me on this idea. What sort of cam are you going with?
Please keep us posted on how the mighty little mouse runs...
Old Sep 17, 2008 | 01:45 PM
lite blue's Avatar
lite blue
St. Jude Donor '12
So you want to make a high revving motor out of an engine that's only redeeming quality is it's low end torque? Yea, sounds great!
I've driven a '68 Z28 with the original 302. It was a hoot, and I like high revving motors. The Ford 289 has an even shorter stroke, with a 4" bore, and it was fun in the '67 Shelby a friend had years ago. Hell, the ZR-1 I have now revs to 7000 easy, and it's probably the most fun you can have with a 350. But the TPI intake will kill you. If you really want a 302, do a Miniram and a blower like Car Craft did some years back. As I remember, it was a great little motor.
To benchracing a L98 - de-stroke it?
Old Sep 17, 2008 | 02:13 PM
cv67's Avatar
cv67
St. Jude Donor '05
Hey, with the TPI it would be the first 302 that actually made any torque at all. Those things were dogs even though they sounded good
Old Sep 17, 2008 | 03:46 PM
Churchkey's Avatar
Churchkey
It will probably be spring time before it lives, putting up a new shop building now.
Cam will be a roller with a 112 or 114 lobe seperation & maybe advanced a few degrees for better low rpm torque. I have to careful with the cam as the heads are already done. I set them up for a torquer flat tappet I have but have changed my mind & currently want a roller.
All I need to complete the assembly is the cam & lifters if I go with a roller, a set of 19# injectors for the piece meal TPI & an engine management system from Howell + a set of long tube small diameter headers which I may build to suit the application.
Trans will either be a 5 speed from an S10 or a 6 speed from a Camero. Both are here, just need to figure the gear ratios & make a choice based on that data, what rear end gearing I want & how I will use the vehicle.
Will post up when work resumes on the project.
Old Sep 17, 2008 | 04:31 PM
pr0zac's Avatar
pr0zac
well nowhere in the OP was there any talk of going over 6000 rpm's. in fact he was talking about spring that would allow only to that rpm. i gathered he was talking more about raising its fall off point around 5k to 6k by dropping cubes making it a "actually be worth revving engine". i think you are over analyzing it.
