timing gears
Old Sep 16, 2008 | 11:22 PM
vettlag's Avatar
vettlag
Default timing gears
ok pulled the timing cover off of the 85. distributar is pointing towards the number one piston and the cam timing gear dot is at 12oclock position and the crank gear is also at the 12oclock position. does this sound correct. my corvette man also shows this but for some reason i think they should cam gear 6oclock and crank gear at 12oclock which is corect.
Old Sep 16, 2008 | 11:42 PM
MK 82's Avatar
MK 82
Where is the rotor pointing?
bee674's Avatar
bee674
Yes that is correct.
Old Sep 16, 2008 | 11:45 PM
bee674's Avatar
bee674
The 12 and 12 oclock with rotor toward #1 cap terminal is correct.
Old Sep 16, 2008 | 11:57 PM
MK 82's Avatar
MK 82
Read This.
vettlag's Avatar
vettlag
the rotor is pointing at the number one piston or atleast very close.
Old Sep 17, 2008 | 12:03 AM
MK 82's Avatar
MK 82
Have you done this before? Rotors don't point at pistons. You need to be concerned with the position of the rotor VS the #1 position on the cap.
Old Sep 17, 2008 | 01:12 AM
vettlag's Avatar
vettlag
my bad rotor is pointing at the1 position on the cap. or atleast very close.
Old Sep 17, 2008 | 01:18 AM
bee674's Avatar
bee674
That should be correct. Also the link that mk82 listed,(read this) has very good info to follow.
Old Sep 17, 2008 | 01:56 AM
vettlag's Avatar
vettlag
now i'm having a hard time getting the crank gear on tried heating in oven get 3/4 of the way on
Old Sep 17, 2008 | 08:25 AM
stealth908's Avatar
stealth908
5th Gear
You have to get it on there right after you heat it up. If it starts to cool while you're still in the process, then you'll either have to take it back off and try again, or beat it the rest of the way on.
If you have access to compressed Nitrous or Nitrogen, then a buddy could blast the crank snout with it right as you gear out of the oven.
Old Sep 17, 2008 | 03:02 PM
eguyett1985's Avatar
eguyett1985
I coat the snout of the crank with some assembly lube and use one of these with my balancer installation tool and never have any problem
http://store.summitracing.com/partde...5&autoview=sku
Old Sep 17, 2008 | 09:16 PM
Brimis's Avatar
Brimis
Yes, that is correct, that's exactly how I replaced my sloppy timing chain.
To timing gears
