93 corvette heater won't blow cold?
Old Jan 6, 2002 | 08:18 PM
waterhead's Avatar
waterhead
Default 93 corvette heater won't blow cold?
I have the electronic climate control. Air will switch to all the diferent modes correctly. Temp goes up and down on control. The display does not flash. I checked for trouble codes according to the manual.Shows on codes.Everything seems to be functioning correctly except air blows out cold. Will not blow warm. Core is not leaking. Does it have a heater control valve that control water flow to the heater core. If so how do you get to it? I can't find a valve in the manual. I'm worried it is the temperature mix door motor. That must be a pain to get to.Need help please.
Old Jan 6, 2002 | 10:26 PM
Scoob's Avatar
Scoob
Default Re: 93 corvette heater won't blow cold? (waterhead)
What's your coolant temp? If you're running extremely cool, perhaps your thermostat is stuck in the open position thus not letting the coolant get warm enough to get heat through the heater core.
That very thing happened to me with 2 of my cars.
Old Jan 7, 2002 | 12:54 AM
bogus's Avatar
bogus
there was just a posting about this... the heater box can get all clogged with debris... and that sucks...
the other cause can be a bad heater core...
Old Jan 7, 2002 | 10:59 AM
BrentDev's Avatar
BrentDev
Default Re: 93 corvette heater won't blow cold? (bogus)
What he said. Mine wasnt working. After an all afternoon flush job, and lots of blown out gunk later - I got it back blowing hot air.
Old Jan 14, 2002 | 12:55 PM
Z06_BluByU's Avatar
Z06_BluByU
Default Re: 93 corvette heater won't blow cold? (BrentDev)
Ok, so where to I blow out all the gunk? How do I get to see if the flap door is operating or not? (BTW: if you havent guessed Im having the same problem!
Old Jan 14, 2002 | 01:35 PM
85 Dave's Avatar
85 Dave
Make sure your radiator is full. If it gets too low, you won't get hot air.
Old Jan 14, 2002 | 03:29 PM
BrentDev's Avatar
BrentDev
Default Re: 93 corvette heater won't blow cold? (BluByU)
I just disconnected the hoses going to the heater core, and reverse flushed from there. I actually blew out the hoses too to help "flush" it a little bit (not a pretty sight! :lol: But - get your tuba breath going!
To 93 corvette heater won't blow cold?
