88 starting problem Please Help
Old Sep 18, 2008 | 11:58 PM
Pila's Avatar
Pila
Cruising
Default 88 starting problem Please Help
Gentlemen, start my engine. Has been setting a long time but ran it to blow it out then wouldn't start the next morning. Fires instantly for a moment then stalls... turns over but won't fire again. Thought it was out of gas so I added a 3 gallon container.
Fuel pump, pressure regulator, diaphram all replaced, a couple miles ago, as well as ECM, computer, wires, plugs, tested injectors. Car has always had a problem of "loading up" and running badly after I drive it for a half hour or so but has always started and run.
Regards!
Old Sep 21, 2008 | 09:29 AM
grayblack88's Avatar
grayblack88
6th Gear
My 88 will start but won't hold an idle ( see my inquiry re topic ). Have you checked for any codes??
Old Sep 21, 2008 | 01:49 PM
engle1147's Avatar
engle1147
Check for codes first. Could be a MAF issue.....unplug it and see if the car starts up any better.
To 88 starting problem Please Help
