Code 34 MAF 85 l98 possible cause?
reason i ask is. i was driving my 85 to the local Corvette specific shop (marcel's Corvette Mechanicville NY) and before i got there i had the SES light come on. i pulled over immediately and checked under the hood without shutting off.. to my suprise i found one of those hard plastic lines to the Air system 3way valve thing that sits under the MAF had popped out of the L connector the the AIR system valve, plugged it in SES light went off shortly later but then came back on before i got home. 30min of total run time before i got it home and pulled the code. i had no change in the way the car was running. just a loud air leak sound when i first popped the hood and found the hose off.
thanks for looking and any info is greatly appreciated.
i read through my haynes manual that was only helpful in telling me what my SES code was, the reason i ask about the AIR system vaccume line is because the repair manual does say to check for air /vac leaks in the intake system.
The code itself Will remain stored until you clear it - the "no power to the ECM for 10 sec" thing. BTW - you don't have to disconnect the Battery to do that - either pull the ECM fuse or disconnect the harness power lead (single in-line connector in the harness sort of next to the battery..).
Anything that causes a large enough vacuum leak will cause the code 34. All it means is that air is being drawn into the motor Without passing thru (and being measured by) the MAF. Hence the low MAF reading and the code. A leak from an "open" small hard plastic vacuum line Might do it - but that ends up as a pretty small leak...
Seems to me that if that One single small vacuum leak causes the code to appear, and Stopping that leak cures the code setting, that you may well have Other vacuum leak(s) someplace that don't quite let enough air bypass the MAF to cause that code. I'd be having a really good look at that possibility
BTW - a code 34 will Normally appear (if it's going to happen at all) right at or immediatly after startup - as the car is settling down to idle. That's where the throttle plates are closed, the IAC valve is wound down to it's most closed setting and the MAF is looking at the lowest normal airflow. Doesn't take much air bypassing the MAF (under those conditions) to let the Measured airflow fall below the code 34 threshold value.
Also - the code 34 diagnostic is one of the things that can be turned Off in the PROM program - you can disable it.
