I have added quite a bit of weight to the nose lowering it as a side effect. I was going to just drop the rear but upon closer inspection I think that it is too low up front now so before I get the alignment done I fear that it will have to come up an inch or so. I find myself gritting my teeth when I see a bump in the road right now. The question is...
Are adjustable coil-over shocks the only way to do this or are there stiffer springs available for our cars?
I haven't broken out the FSM yet but I have seen a lowering thread that had the spring out. It seems pretty simple to swap it out but I get the feeling that the coil-overs might be the only way to add height.
What do you think...too low? I am worried more about suspension travel than asthetics.
