87 corvette Don't fire
Old Sep 22, 2008 | 01:25 PM
jkeigley's Avatar
jkeigley
1st Gear
Default 87 corvette Don't fire
I just purchased this 87 corvette, it ran fine, just passed emissions and seemed good. Parked it one day , about 3 hours latter it would not start. Cranks but no spark. Any ideas, iv'e checked fuses. Have voltage to coil. But noe spark at plug.
Old Sep 22, 2008 | 01:32 PM
rick lambert's Avatar
rick lambert
Hope you have a Factory service manual. You may want to pull the ignition control module, take it to any Autozone, they'' test it for free. Just make sure they run it through at least 10 cycles. Another thing you may want to check is the coil.
Old Sep 22, 2008 | 07:23 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/corvette86/En...ButWontRun.pdf
http://members.shaw.ca/corvette86/Ig...System-EST.pdf
http://members.shaw.ca/corvette86/Co...0View%2086.pdf
Old Sep 22, 2008 | 07:46 PM
anesthes's Avatar
anesthes
87 didn't have crossfire...
Old Sep 22, 2008 | 09:04 PM
AGENT 86's Avatar
AGENT 86
What have you been smoking ??
Old Sep 22, 2008 | 09:08 PM
anesthes's Avatar
anesthes
Hrmm.. wow..
-- Joe
Old Sep 22, 2008 | 11:16 PM
AGENT 86's Avatar
AGENT 86
Hrmm.. wow..
-- Joe
I was referring to the crossfire comment ??
Old Sep 23, 2008 | 06:33 AM
anesthes's Avatar
anesthes
I know.. I'm not sure...
-- Joe
Old Sep 23, 2008 | 08:31 AM
AGENT 86's Avatar
AGENT 86
-- Joe
My comment was a friendly poke, as I saw no reference from the OP mentioning anything about a crossfire in his 87.
Old Sep 23, 2008 | 09:12 AM
anesthes's Avatar
anesthes
I know. And I'm not sure what I was smoking. hence the "wow" in my response. I re-read the thread and said "what the heck was I saying here..."
I must be getting old.. ?
-- Joe
Old Sep 23, 2008 | 11:11 AM
MK 82's Avatar
MK 82
I have never done that!
Old Sep 23, 2008 | 11:00 PM
jfb's Avatar
jfb
There is a pickup coil in the bottom of the distributor and its pulses are fed to the spark module inside the distributor. You can get the spark module tested at most auto stores. If good, then I would test the spark coil. If you pulse 12v on the primary wires, you will get a spark on the high voltage terminal. If ok, then check for low resistance on the pickup coil.
Also, look at the rotor. There is a spherical well on the center of the rotor and if you have an open circuit plug wire, a spark can make a carbon path through the well on the rotor and you will get weak/no spark. Look at the rotor carefully. Also look inside the distributor cap for carbon tracks and a broken missing center carbon button.
Old Sep 24, 2008 | 04:07 PM
Da Mail Man's Avatar
Da Mail Man
......i have (or responded to) a recent post today on part of this....
Old Sep 24, 2008 | 04:17 PM
rick lambert
Hey Mail man, how's your latest module holding up? last I read you were going to replace the condensor.
Old Sep 24, 2008 | 04:21 PM
Da Mail Man
.....ugh!....see the last post i just made here! ;
http://forums.corvetteforum.com/show...2083818&page=2 post 28
To 87 corvette Don't fire
