Question on Cam Installation...
Old Jan 7, 2002 | 04:38 PM
TIMSPEED's Avatar
TIMSPEED
Default Question on Cam Installation...
On my 87, if I had the intake and heads off, would it be too hard to pull the cam while I'm at it? I see it as this (with the heads/intake/lifters off):
1.) Pull out radiator and pull up A/C Condensor
2.) Take water pump/all pulleys off
3.) Pull timing cover off/timing chain
4.) Pull camshaft out
Installation is probably reverse of removal?
Anyone know from experience? Thanks in advance!
Old Jan 7, 2002 | 04:44 PM
scorp508's Avatar
scorp508
Default Re: Question on Cam Installation... (TIMSPEED)
Unbolt engine mounts and jack the engine up an inch to clear the crossmember with the cam.
Old Jan 7, 2002 | 04:57 PM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: Question on Cam Installation... (scorp508)
Unless the l98 sits about a foot lower than the LT1 the cam hitting the cross memeber shouldn't be a problem. What is a problem is getting the crank hub off. If you can get the timing chain cover off you shouldn't have any trouble from there.
Old Jan 7, 2002 | 05:07 PM
TIMSPEED's Avatar
TIMSPEED
Default Re: Question on Cam Installation... (Nathan Plemons)
Sounds good! I've had the complete intake and all the pulleys off on my 85, and it was a cinch! Wow, looks like my car will be getting in the low 12's MAYBE high 11's before summer!
To Question on Cam Installation...
