Fuel issue on 95 - please help !!!
Old Sep 24, 2008 | 04:59 PM
MK 82's Avatar
MK 82
Please refresh my memory as to what question I asked.
Originally Posted by Redeasysport
Nothing personal just answering the question. Yes the chance increases because the concentration increases. You asked and I answered end of debate.
Old Sep 24, 2008 | 05:12 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
The question is whether or not the chance of plugging the sock or inline filter increases as the fuel level drops..
Take a glass of muddy water and toss it at a "T" shirt. Take a glass of wet mud and do the same. Which will coat it more? Same mixture different concentrations.
Old Sep 24, 2008 | 05:15 PM
MK 82's Avatar
MK 82
You haven't listened to a word I've said. I withdraw from this debate before I say something I will regret. I apologize to the OP for this soap opera.
rick lambert's Avatar
rick lambert
Yes, and x grams that passes through the sock, and hopefully gets caught by the inline filter, of course there's injector cleaners for the other x grams that slip through the inline filter. Unfortunately we don't live in a perfect world. Incidently Multech injectors have a fuel screen in them, not sure all injectors do. I wonder what that's for.
And I'm not fighting any battles. Engineers, give me a break, they've created as many nightmares as they've solved.
Old Sep 24, 2008 | 05:18 PM
MK 82's Avatar
MK 82
This is probably the regret part, but I have a realtor explaining filtration to an engineer. And then insulting engineers in general.
Old Sep 24, 2008 | 05:24 PM
Redeasysport
They invented the opti and located it.Doomed the LT1 to a 4yr life span
I have worked with some who should not be able to carry sharp objects and think they are legends in their own mind. Yes GM engineers at that
Old Sep 24, 2008 | 05:27 PM
MK 82's Avatar
MK 82
So are you saying that all engineers are incompetent?
Old Sep 24, 2008 | 05:31 PM
Redeasysport
Nope I worked with a few good ones. About 1 in 4 or 5. Too many did not have a bit of common sense and could not grasp the transition from theory to practical application.A lot like the Opti. Great in theory lousy in application even when vented. If it were mounted on the rear of the engine like a conventional distributor they would have been hailed as ground breaking instead of just broken.
Old Sep 24, 2008 | 05:37 PM
MK 82's Avatar
MK 82
So 75 to 80% of engineers are incompetent. Interesting.
What percentage of electricians are incompetent?
Old Sep 24, 2008 | 05:50 PM
rick lambert
Boy, if that wasn't a personal attack! So here's my back round. I'm 64 and yes a Realtor, for 21 yrs. Before that I was a Machine fabricator and later a research and design specialist, plus I owned my own fabrication business. Worked directly with 100s of engineers. You'd be shocked to know what I've built. Along the way we also built hundreds, yes hundreds of fuel tanks, most were for new equipment, some were replacement tanks. I can gurantee you I've seen the inside of more used fuel tanks than you''ll ever see. I can't begin to tell you how many times I've solved an engineers problem or mistake...their human too. And I'm not knocking your engineers degree...whatever field that is in. Engineers aren't Gods. Like anyone else they do make mistakes.
And if you honestly think all any intank pump needs is a sock to prevent sediment or contaminates from getting to the injectors tell it to the General, or any other car manufacturer. Just tell them in your engineering opinion they don't need an inline filter!
I've also built alot of cars, started when I was 15 yrs. old.
Old Sep 24, 2008 | 06:02 PM
MK 82's Avatar
MK 82
You left out the training in filtration of suspended particles which most engineers, me included, are trained in.
Old Sep 24, 2008 | 06:12 PM
MK 82's Avatar
MK 82
Excuse me but I think you insulted engineers first. I am married to a realtor.
Old Sep 24, 2008 | 06:41 PM
  #33
rick lambert
Well excuse me! May I ask what type of engineering degree you have?
I certainly don't mean to offend, but wasn't it an engineer who designed the Multech injectors? the unvented Opti?
This is what I did before becoming a Realtor (which I recieved the first College degree in the U.S). If you eat anything out of a can, I helped develope it! the harvestor, the coreing, the pealing, the canning and cooking of the product, I helped develope it. Worked for FMC for over 10 years. Helped develope alot of airline equipment, military equipment and yes, even the first space craft launching platform! AND, if you use zip lock bags, I also helped develope the first prototye!
I'm definetly not saying engineers are bad.........whatever their field of expertise is, but like all of us, they do make their mistakes! and sometimes they're very expensive!
So don't blow your horn by saying "I'm an engineer" qualify it! you can't be a specialist in every field! Just because I took intro to economics, history to U.S. economics, micro economics, macro economics doesn't make me an expert in economics!
Old Sep 24, 2008 | 06:47 PM
  #34
MK 82's Avatar
MK 82
Well shut my mouth. Nice waffle.
Old Sep 24, 2008 | 07:10 PM
  #35
rick lambert
Waffle? I simply asked you a question. What field of engineering do you specialize in? Structural, mechanical, electrical, hydraulics, etc. ect. etc. many fields of expertise, you can't be an expert in all fields!
Old Sep 24, 2008 | 07:17 PM
  #36
MK 82's Avatar
MK 82
It's in my profile. The degree will get you into the argument but you must get yourself out. I don't want to fight about this. It is a debate.
Old Sep 24, 2008 | 08:43 PM
  #37
Redeasysport
I can only speak about the engineers I worked with most under 30. I would like to think they all got better at it with age but most of them got fired from GM. The ones that didn't moved up. Electricians? It depends where and what qualifications they have a lot of them never went through an apprenticeship and a lot of those are questionable.Some are good too. I am teaching a class of them at the local Tech college in a 4yr program. Mostly younger guys and some are sharp others are not. Just like life.
To Fuel issue on 95 - please help !!!
Old Sep 24, 2008 | 08:47 PM
  #38
Redeasysport
He was in the military for 23yrs and working on Corvettes for over 30yrs too or so he said. I did not know he was a jetjock might explain some things.
Old Sep 24, 2008 | 09:45 PM
  #39
MK 82's Avatar
MK 82
You know, that is not the first time that you have insuated that I am a liar. Thanks for the profile report.
Are Fighter Pilots and Airline Capts incompetent too?
Old Sep 24, 2008 | 10:23 PM
  #40
Redeasysport
I am not insinuating anything just reporting what you have said. You have done all the insinuating here and I am done with this "debate".
