Fuel issue on 95 - please help !!!
Old Sep 24, 2008 | 11:26 AM
Meloyelo90's Avatar
Meloyelo90
Default Fuel issue on 95 - please help !!!
Apologize in advance for the long thread...
Last week girlfriend drove the car dry, as soon as I got in it the car began stalling / running rough. I got to a gas station, put gas in but it kept dying every mile or so. It would start right up so I got it home eventually.
I figured maybe the fuel level was so low the FP pumped junk into the filter, so I changed the filter out. Car ran perfect for two days, problem fixed ! Not so fast, it slowly began dying again as I was in the middle of driving, now it sits in the driveway and won't start.
Is it possible there is so much junk in the line that it's clogged the filter again ? Maybe the lines are clogged ? Is it possible the fuel pump is now on it's way out ? When I turn the key I hear it initialize. This is very confusing to me since it ran great for two days after changing the FP.
Any help would be GREATLY appreciated - need to get her back on the road. Thanks !
Old Sep 24, 2008 | 11:34 AM
MK 82's Avatar
MK 82
Running the tank dry does not "pump more junk." Think about it. The pickup is in the bottom of the tank.
However, running the pump dry tends to overheat the pump. If it was running fine prior, it is most likely the pump.
Check the fuel pressure.
Old Sep 24, 2008 | 12:03 PM
Meloyelo90's Avatar
Meloyelo90
I am getting a fuel guage today to test, but I had seen in some other threads that is was possible for the pump to send junk through the lines, which is why I swapped the filter. If the pump was bad I would think the filter swap wouldn't have fixed the problem (for a couple days). Either way it does point to the pump now, just didn't want to have to go down that road and was hoping maybe someone had this happen in the past.
Thanks.
Old Sep 24, 2008 | 12:39 PM
MK 82's Avatar
MK 82
Actuaaly, replacing a pump on these cars is pretty easy.
Old Sep 24, 2008 | 01:01 PM
Meloyelo90's Avatar
Meloyelo90
Searching the threads it doesn't look too hard - nothing compared to the opti / wp replacement I did two months ago. I was initially thinking the replacement was similar to the F-body's where you had to drop the tank, but this job doesn't look too hard. I'm sure I'll end up making it a challenge though.
Old Sep 24, 2008 | 01:30 PM
rick lambert's Avatar
rick lambert
Get the fuel pressure guage on it before you start throwing $$$ at it. The pump is cooled by the fuel in the tank so it's a possibility you damaged it. And you can suck up sediment.....you'll see that if you replace the pump, the sock (filter will be really nasty). Pump and sock run about $100., fuel pressure guage ( a very important tool) runs $35-40. at AutoZone. And since you don't have Multech injectors I'd run some Techron through it.
Oh yeah, if you do need to replace the pump (it's very easy) just becareful when you pull the lid off not to damage the rubber gasket.
Old Sep 24, 2008 | 01:43 PM
MK 82's Avatar
MK 82
Nobody said that you can't suck up sediment. You will not suck any more sediment from a near empty tank than you will from a full tank.
The stuff settles to the bottom.
Old Sep 24, 2008 | 02:15 PM
rick lambert
Sorry, but all sediment doesn't settle to the bottom, if it did we wouldn't have a need for the sock or inline filter. Simple motion of a car can keep sediment floating around.
Old Sep 24, 2008 | 03:01 PM
MK 82's Avatar
MK 82
Let me see if I have this. Your theory is that the sediment stays evenly distributed throughout the gasoline. Lets say there is X grams of sentiment per gallon. The engine would suck up X grams per gallon regardless of whether that gallon was the first used or the last. What am I missing?
You still need the sock.
Old Sep 24, 2008 | 03:17 PM
Meloyelo90's Avatar
Meloyelo90
Looks like step one will be fp gauge tonight, then we'll go from there.
Also going to check to see if there is water in the gas and will probably replace the gasket anyway while I'm at it. We've had some very severe rain over the past couple days so with my luck water got into the tank somehow at the same time the tank ran low causing multiple issues. Quoted $94 for pump and sock, 40 for gauge and since this car is stock (daily driver) there's really no need to go with a better flowing fp. If there's no pressure at the gauge reading then it's probably safe to assume the fp got fried unfortunately.
Old Sep 24, 2008 | 03:24 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Sorry, Simple motion of a car can keep sediment floating around.
And that is why it has a sock in the tank. To the OP I have read of some socks getting nasty and acting like a bad Fuel pump/filter. All the sock is is an extra screen to keep larger sediment out of the fuel loop or we would be changing fuel filters every year or so..The correct way to diagnose this is to put a fuel gauge on the scrader valve on the passenger side of the rail and check FP when you turn the key on,when it is running, and after you turn it off. Should be ~42PSI give or take a couple and maintain it at all 3 tests. If it drops quickly after shut down it may be a bad injector or FPR but it will probably slowly drop at shut down over an hour or so but not to zero..
Old Sep 24, 2008 | 03:34 PM
MK 82's Avatar
MK 82
sediment n. Material that settles to the bottom of a liquid.
Whether a foreign particle settles out in gasoline is a function of its density realtive to gasoline and the degree of agitation.
The real nasty heavy stuff will settle and be difficult to unsettle. Lighter particles that are only slightly denser than gasoline will unsettle easier. Particles that are less dense than gasoline will stay in suspension.
It is these particles that dislodge from the bottom that are stopped by the sock. The rest is probably too small for the sock. They are caught by the inline filter.
Old Sep 24, 2008 | 03:39 PM
Redeasysport
Originally Posted by MK 82
sediment n. Material that settles to the bottom of a liquid.In a static state
Take a bottle of water and add sediment(dirt?) to it and let it settle. Now shake the bottle what happens. Same principal as the gas tank.
Old Sep 24, 2008 | 03:45 PM
MK 82's Avatar
MK 82
Did you read the rest of the post? We are talking about the same thing.
The question is whether or not the chance of plugging the sock or inline filter increases as the fuel level drops. I said it does not increase significantly assuming the dislodged sediment is dispersed evenly.
Old Sep 24, 2008 | 04:14 PM
rick lambert
And the worst time to fill your tank is just after the fuel trucks have filled the tanks, guess why? stirs up the sediment!
To the OP, get a can of Heat (sp) from the auto parts store, dump it in the tank, that will take care of any condensation in the tank and also the fuel line.
Mk 82, think of it this way. There's always a certain amount of sediment (yes, sediment means something that settles to the bottom) or contaminants floating around in a continously moving vehicles fuel tank. That's settles, but it doesn't attach to the bottom. So when you run a 20 gallon tank down to "barely making it to the gas station" your simply sucking up the worst, not only causing the pump to over heat.
I'll tell you, my sock was very nasty when I pulled it.
Old Sep 24, 2008 | 04:30 PM
MK 82's Avatar
MK 82
The pump has a big filter that takes that stuff out. I understand the mechanics of it. I don't think you do.
Old Sep 24, 2008 | 04:41 PM
Redeasysport
Again and theconcentration increases with less in the tank making it more probable to coat the sock. I guess he just wants to argue and doesn't get it himself.
To Fuel issue on 95 - please help !!!
Old Sep 24, 2008 | 04:47 PM
MK 82's Avatar
MK 82
Tell me why you continue to make these personal with me. Why not leave it to the engineers?
Why not let the person I was replying to fight his own battle.
Old Sep 24, 2008 | 04:53 PM
Redeasysport
Nothing personal just answering the question. Yes the chance increases because the concentration increases. You asked and I answered end of debate.
Old Sep 24, 2008 | 04:57 PM
MK 82's Avatar
MK 82
Do you understand that suspended material sucked up by the fuel pump sticks to the sock. That means that the concentration of suspended material does not increase. There is still X grams/ gal.
