quick question up alternator upgrade
Old Sep 24, 2008 | 04:19 PM
Da Mail Man's Avatar
Da Mail Man
Default quick question up alternator upgrade
...88 vette here...have a STOCK alternator which is 105 amps (cs series i believe) ....what OTHER VEHICLE (type and year) uses the same styled alternator and has a higher current output that will directly bolt up to the '88?....i don't mind reclocking if i have to.....thanks!
Old Sep 25, 2008 | 07:58 AM
Da Mail Man
.......ttt....
Old Sep 25, 2008 | 10:02 AM
redrose's Avatar
redrose
you have a CS-130...many early 90's GM cars (big oldsmo/buick/etc) have CS-144 alts with higher output/better cooling, visit your local j-y and pick one...will not be a direct bolt-on but with a lucky pick (or a bit of observation before harvest) you will only need to narrow one lug on the CS-144 (takes abt 4 min with a hacksaw) and it will fit...all CS series alts (110, 130,144) are wired the same internally and your vette harness plug will work, power lead (the big red one) may have minor issues but slight rework will get it on...rear alt brace must be fabricated...serp belt length same as oem...expect trouble if you try to "clock" a CS alt, "new" mfg methods no longer give proper internal alignment if original case halves are re-oriented.
Old Sep 28, 2008 | 06:00 AM
Da Mail Man
.....thanks for the reply...is the case size the same?...if so, what about gutting a blown out cs-130 and taking the guts out of a cs-144?..will it fit?
Old Sep 28, 2008 | 07:54 AM
Sliding's Avatar
Sliding
I've bought and installed CS-144. I've bought it here:
http://www.alternatorparts.com/CS-144_Special_offer.htm
I took 140 amps.
Some grinding was necessary to make it fit, but not much (pic3).
I also upgraded to thicker wire.
Pics:
New vs old
Some grinding is required here
New wire
New vs old wire
Installed
Old Sep 28, 2008 | 10:00 AM
redrose's Avatar
redrose
144 is a 130 on steroids, bigger and heavier...check Sliding pics...i have not tried a 144/130 guts transplant, suspect differences due to output ratings...btw, cs-110 (found on early 90's mid-sized GM) is smaller diameter and lighter weight than 130, if those features are important, lower output of course.
Old Sep 28, 2008 | 02:38 PM
Da Mail Man
I took 140 amps.
Pics:
New vs old
New wire
New vs old wire
Installed
...thanks for the response...looking at the picts i am surprised that the larger can be used at all!...i think there was mention of a rear brace of sorts...is that a necessesity?....where is the red wire attached to that you replaced as i never really noticed?
Old Sep 28, 2008 | 02:41 PM
Da Mail Man
.....would be curious to see if guts swap could take place and that the 144 is meerly a thicker case...humnnn...
Old Sep 28, 2008 | 02:57 PM
Sliding's Avatar
Sliding
You're welcome!
I can't tell you for sure about rear brace because I don't have it on my car. I took it off when I installed headers and never put it back on.
I installed two new (thicker) wires. One goes from alt to distribution point
that is located under the battery. Other goes from that distribution point to the battery.
Old Sep 28, 2008 | 03:01 PM
Da Mail Man
You're welcome!
...that's where i thought it went but, it's been a long time since i've looked....i have 5-6 kits to upgrade the older style alts from approx 60i to 100i in my garage but, since i don't use that style in any of my cars, i really don't need 'em.......when i did that conversion, everything was the same and fit well.......
To quick question up alternator upgrade
