low end miss
Had a lot oif expense repairs done on my '89 vette recently. 1 injector replaced, the others taken and soaked. Maf, EGR and TP sensors checked and adjusted as needed. Mechanic said I might have a burnt intake valve but when I got it back it ran pretty good.
Had Bosch Platinum plugs , mechanic said cylinder in questions showed all the lean signs but gave engine 6-12 months to live. Decided to install new plugs, (aluminum heads) and went with NGK's. Again, ran fine until I was told that I should have used an anti-seze . Pulled all the plugs on driver's side, coated the threads, a little dialetric in the boot, plugs back in and now seems like a dead low speed miss and back firing through the exhaust. Checked firing rotation, boot connections. Lost!
Where have I gone wrong?Can't believe that the suspected intake took a dump between plug changes. Thanks for any help or suggestions.
