Bose CD Fade Button
Old Sep 26, 2008 | 05:42 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Default Bose CD Fade Button
I just recently purchased a Bose CD to replace the Bose cassette in my '90. However the fader button on the CD player is missing and there is just a hole. What all do I need to replace it? Should the button from my cassette unit just pull out and go into the CD unit?
Old Sep 26, 2008 | 08:18 PM
MaxLean's Avatar
MaxLean
You've got a problem there. There should be a shaft emerging out of the radio that the **** attaches too. It's not supposed to come out and since yours did, you likely have a damaged potentiometer inside. Just pull the **** off your old radio and it will be obvious.
Scott
Old Sep 26, 2008 | 08:38 PM
Kubs's Avatar
Kubs
Can I swap it with my cassette unit?
Old Sep 26, 2008 | 09:46 PM
MaxLean's Avatar
MaxLean
If you're handy with a soldering iron. It will require internal surgery. Also, on the non Bose tape unit, that **** is a two function item, fade and balance. On the Bose units, it's only a fade. Otherwise, I would think it's possible.
Scott
Old Sep 26, 2008 | 10:47 PM
Kubs's Avatar
Kubs
Thanks. Ill look into it. My cassette unit is a Bose.
To Bose CD Fade Button
