Transgo reprogramming kit
Old Sep 26, 2008 | 05:57 PM
UTTPIVette's Avatar
UTTPIVette
2nd Gear
Default Transgo reprogramming kit
Does anybody have this kit installed on a TPI vette? Does it help at all? What do optional stick shift and shift command? I mean I assume it lets you select the gear but how does that work with your factory stick?
Thanks.
Old Sep 26, 2008 | 06:33 PM
janarvae's Avatar
janarvae
I've got it on my '91 L98 700R4. The manual stick mode means you must shift like a manual without a clutch. Forum member Sliding did it and has a thread dedicated to his rebuild.
To clarify, I don't have the manual mode, I am just aware of it from the directions that came with the kit when I installed it. I am 100% certain though that Sliding has it installed in his LT1.
Jonathan
Old Sep 26, 2008 | 06:42 PM
UTTPIVette's Avatar
UTTPIVette
2nd Gear
But how do you shift it like a manual, is it a bumpshift like in the new Mitsubishis? Do you still put it in drive, how exactly does it work on the stick itself?
Sorry I don't mean to sound dumb I am just having a hard time visualizing it.
Old Sep 26, 2008 | 06:51 PM
preacherman's Avatar
preacherman
YOu shift it through the gears 1-2-3 etc. just like before. The difference is you can downshift at any speed and it will hold the gear you are in until you move the lever.
Old Sep 27, 2008 | 05:09 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I have the TransGo in "auto" mode and it chirps the 1-2 at only 1/2 throttle; the upshifts are lightening quick...
To Transgo reprogramming kit
