gear drive installed
Old Sep 28, 2008 | 03:14 PM
vettlag's Avatar
vettlag
Default gear drive installed
ok the gear drive is in my 85 ran good for the first few min now doesn't run well at all the engine light not on so is my knock sensor creating this problem
Old Sep 28, 2008 | 04:23 PM
pologreen1's Avatar
pologreen1
I am no expert but I have checked in to doing this mod many times!! I have heard you can't use it because of the knock sensor. only one person I have spoken with has used it and it was the quiet one and said it works. Everyone has discouraged me for years on putting that on my c4 vettes!
Old Sep 28, 2008 | 04:45 PM
vettlag's Avatar
vettlag
My question is if my knock sensor is picking up a false knock will this cause my car to not want to run correctly
Old Sep 28, 2008 | 04:46 PM
Pete K's Avatar
Pete K
It could be. Connect a scanner, and observe the knock counts.
Old Sep 28, 2008 | 04:55 PM
pologreen1's Avatar
pologreen1
yes it is too much for the knock sensor and it affects timing I was told!
Old Sep 28, 2008 | 04:56 PM
pologreen1's Avatar
pologreen1
this is why most have dua roller timing chains instead!
Old Sep 28, 2008 | 05:22 PM
MK 82's Avatar
MK 82
You were warned that this would happen.
Old Sep 28, 2008 | 05:53 PM
Corvette Chris's Avatar
Corvette Chris
Can't do the gear drive.
Old Oct 2, 2008 | 11:22 PM
vettlag's Avatar
vettlag
gear drive works fine with the knock sensor disconected drives fine to
Old Oct 2, 2008 | 11:24 PM
Corvette Chris
Kinda defeats the purpose of the knock sensor, though, doesn't it?
Old Oct 2, 2008 | 11:26 PM
vader86's Avatar
vader86
Gear drives cause problems for the knock sensor, and you should not disconnect the knock sensor because then you wont have any way of saving things if a problem occurs with type of fuel or timing being thrown off.
Old Oct 3, 2008 | 01:25 AM
pologreen1's Avatar
pologreen1
GOOD LUCK enjoy ot!! keep us posted!
Old Oct 3, 2008 | 02:00 AM
cv67's Avatar
cv67
St. Jude Donor '05
Old Oct 5, 2008 | 01:56 AM
vettlag's Avatar
vettlag
ok so the gear drive works great no engine light nothing i drove around town today not sure on the 85 ecm how often it checks sensors. what year did the ecm's first come out.
Old Oct 5, 2008 | 02:24 AM
TA's Avatar
TA
Reading your posts makes my head hurt
To gear drive installed
