Exaust ona budget..
Old Sep 30, 2008 | 05:01 PM
Jimbo3087's Avatar
Jimbo3087
Default Exaust ona budget..
What is a good sounding exaust without spending $1,500??
Old Sep 30, 2008 | 05:21 PM
SCCA VETTE's Avatar
SCCA VETTE
how loud you want it?
Old Sep 30, 2008 | 05:24 PM
Jimbo3087's Avatar
Jimbo3087
A little louder than stock but still sounding good
Old Sep 30, 2008 | 06:26 PM
Demonic85's Avatar
Demonic85
My exhaust sounds great and didnt cost a fortune, its very loud though. Would have been a lot cheaper if i'd used different mufflers. You could use a new pair of stock ones (like $150).
$230 used long tube headers
$210 straight pipes
$450 Magnaflow SS mufflers
Old Sep 30, 2008 | 06:46 PM
Chris Kennedy's Avatar
Chris Kennedy
I understand your predicament, and my recommendation would be to simply go with a set of muffler eliminators that you see advertised in the magazines. Unless you make all sorts of changes such as getting rid of catalytic converters (illegal), installing headers etc., none of these expensive systems seems to make a difference that is enough to justify the cost. Lots of people (like me) seem to be going through multiple aftermarket systems. Muffler eliminators are simple, inexpensive and will give you a louder and more aggressive tone. I am going back to them, myself, from a TPIS system that I don't like much.
Good luck!
/s/ Chris Kennedy
Old Sep 30, 2008 | 06:51 PM
GUSTO14's Avatar
GUSTO14
Does you car have the original mufflers on it? If it does, there is a very inexpensive mod you can do to liven up the sound...
GUSTO
Old Sep 30, 2008 | 06:53 PM
SCCA VETTE's Avatar
SCCA VETTE
Headman long tube headers = $200 used (like new) from forum
Summit 3" H pipe = $40
(2) Dynomax 3" race mufflers = $80 total
3" exhaust installed at local muffler shop = $260
It is a little loud durring normal driving. I compare it to a Mid Year with sidepipes. When on the throttle it is LOUD and sounds like a race car.
I have no resonance (spelling) driving down the road.
Old Sep 30, 2008 | 06:58 PM
myturn89's Avatar
myturn89
what is the inexpensive modification to stock mufflers??
Old Sep 30, 2008 | 07:10 PM
GUSTO14's Avatar
GUSTO14
The stock mufflers up until the early 90's only had one outlet open. If you open the second outlet, it will wake up the sound dramatically without undue resonance.
The straight outlets are easy to do with an arc welder by just reaching inside with a new "long" rod and "burning" a large hole in the casing. The '84's used the down turned tips, so you might have to remove the tip first to cut the hole, then have the tip welded back on.
A local shop here showed me this and I promise, you won't be disappointed with the sound.
My exhaust has only 8k on it and I couldn't see replacing it without giving this a try.
Good luck... GUSTO
Old Sep 30, 2008 | 09:25 PM
LTxDave's Avatar
LTxDave
Find someone with an LTx car that has swapped an aftermarket system on. I'll have one off of one of my cars in the near future (without the rear mufflers) if you're interested. 2-3/4" true duals.
Old Sep 30, 2008 | 11:01 PM
SCCA VETTE's Avatar
SCCA VETTE
Here is a sound clip of mine if you want to hear it. Dont watch the video though it will make you
Old Oct 1, 2008 | 08:06 AM
GUSTO14's Avatar
GUSTO14
Phil, now that is wild... just a bit louder than my '85...
GUSTO
To Exaust ona budget..
