Shake down run/all is good...mostly
Old Sep 30, 2008 | 09:31 PM
Tom 35th anniversary's Avatar
Default Shake down run/all is good...mostly
Well today i finished the exhaust, filled the fluids, set the timing and took the 88 out for its break in/shake down cruise. The new zz4 sounded great, and pulled decent. The Pete K. tranny with torque converter shifted nicely. But DAMN!!!! After i parked it I noticed water seeping from under the intake on the passenger rear side of the motor, right where the water passage is. Is it possible a retorque of the bolts will cure this? There is no water in my oil or visca versa. There is a couple of other things like the car now idles high, around 1700 rpm, and my fans all of a sudden dont work. All in all I'm happy to have it running again after 2 years.
Old Sep 30, 2008 | 09:40 PM
engle1147's Avatar
engle1147
I believe in work on one problem at a time....but in this case addressing one problem might fix 2. Were the the faces of the intake, heads and deck super clean when you bolted them up? If you are leaking coolant and have a high idle you could be looking at a gasket problem @ the intake.
Old Sep 30, 2008 | 09:48 PM
Yes, all were spotless clean. I torqued all bolts to spec, even double checking. I thought about retorquing, but I'll have to pull plenum and runners off to do that. I might as well pull the intake too, and replace the gaskets if i have to go that far.
Old Sep 30, 2008 | 10:08 PM
Corvette Chris's Avatar
Corvette Chris
For the fans -- do you have the wheel well in, that has the relay on it? Is it connected?
Been there done that, scared the hell out of me to watch the temps climb like that.
Old Oct 1, 2008 | 07:58 AM
Wheel well is in. When I first put battery in and started up the fans worked. Now nothing. I'll just have to start looking for the cause.
Old Oct 1, 2008 | 08:31 AM
Iroc57's Avatar
Iroc57
I put just a light coat of black RTV around the water passages of the gasket only and have never had an issue with leaking. It may not be necessary but it just makes me feel better
To Shake down run/all is good...mostly
