ZF to TKO600 install thread?
Tremec tranny arrives next week, install probably on October 11th .
Keisler has been in several mags so maybe everyone has already seen this.
It takes more time to get the photos and build the content, but if
you are inclined to create a write-up, this would certainly be of
interest to me.
As an A4 owner, the swap is not something I am bound to be
duplicating myself. However, I find I always learn something new
from watching how others go about their projects.
Most of my curiosity was based around the shifter and c-beam TQ mount, so I can get good and close up pics of this stuff... should be interesting..
to be continued...........
I see the advantages for the TKO being,
1. lower cost Clutch & FW components and more varied options for clutch and Flywheel components, i.e. Push vs Pull Clutch, bolt on TOB's etc..
2. TKO cost of repair is probably less, and I say this because I have talked with ZF Doc and for starters he gets $600-$800 to open it up to evaluate the ZF and then add shipping each way ($200 each way from INDY) plus cost of components (they dont make the ZF anymore),
3. the TKO weighs 105 lbs the ZF = 160/lbs,
4. there is a wider network of service centers,
5. and of course, no rocks in the box sound.
6. Not really an advantage but I never used the 6th gear unless i was cruising 80+ mph
Had to Heli-Arc weld the dimple impression in my clutch fork because it cracked where it pivots on the clutch fork pivot stud and it galled up the pivot stud... should be strong now and good to go
Well,, the CO's are reversible if I put the springs back in, and if I want I cna put the 4+3 back in, and I still have the original 350 block, so I could put it back top stock for @ $5000
after I have my head examined!
I look at the zf as a 4 speed with an overdrive. 5th gear is a large jump from 4th and 6th is obviously for fuel economy. WIth the high rpm motor I cannot cruise below 2500 rpms or so because there is no torque down low so I don't want any overdrive.
Good luck with the swap please keep us informed !!
