Dewitts Instructions
Old Oct 1, 2008 | 05:43 PM
dan6712cc's Avatar
dan6712cc
Default Dewitts Instructions
I'm about to install my Dewitts radiator and can't find the instructions, can anyone post them? I have the spacer plates and foam seal strips but no pre-cut rubber mounts. Any help is appreciated
Old Oct 1, 2008 | 05:48 PM
rickneworleansla's Avatar
rickneworleansla
I thought you used to be able to download the instructions from the Dewitt website. Maybe I'm thinking of something else.
Here's my install...
http://forums.corvetteforum.com/show...ghlight=dewitt
Old Oct 1, 2008 | 06:56 PM
dan6712cc's Avatar
dan6712cc
I couldnt find the instructions on Dewitts website, they just had them for the C5 but they don't show where to place the spacers and foam strips. I'd rather not cut anything if I can get away with it, that's why I was wondering where to place the spacers and foam if needed.
Old Oct 1, 2008 | 06:57 PM
rickneworleansla
I found this on my computer for my 95 A90 Dewitt radiator. I must have scanned it when I got my radiator. Note: Not sure if any changes have been made since.
Old Oct 1, 2008 | 07:21 PM
MK 82's Avatar
MK 82
He modified the installation so it does not require trimming the shroud. He furnishes a kit with spacers and foam strips. He promised to post a PDF of the new instructions but I never saw it. I have looked on the site several times.
Old Oct 1, 2008 | 08:35 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
You're right and I still haven't done it yet. Basically you still have to cut the rubber cushion to allow for the thicker core, but that's it. We include fan spacer bars at no charge and these simply sandwich between the fans and the fan shroud. Longer bolts are provided. This kit is sold by the competition for $75. We also include foam seals to attached to the upper and lower channels to prevent air going around the core.
Old Oct 2, 2008 | 07:09 AM
Tom Piper's Avatar
Tom Piper
Originally Posted by Tom DeWitt
...We also include foam seals to attached to the upper and lower channels to prevent air going around the core.
That is a big plus that GM forgot.
Those seals are worth it.
Something else worth looking into is plugging all the holes in the radiator shroud that stops you from pulling the hot air under the hood in front of the radiator -- especially the hole where the A/C condenser lines enter.
Tom piper
Old Oct 2, 2008 | 10:25 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
They do not have the best customer service either.
Old Oct 2, 2008 | 07:20 PM
MK 82's Avatar
MK 82
Who is they?
To Dewitts Instructions
