T-Stat Q....
Old Oct 2, 2008 | 01:29 PM
Corvette Chris's Avatar
Corvette Chris
Default T-Stat Q....
Just out of curiosity...
I'm currently running a 180 stat in my '86L L98. Temp outside today is 54 degrees, when driving earlier, the coolant temp was staying between 175-178 degrees. Oil was 190-195. I'm fine with these temps.
My question is this, if I were to go to a 160 stat, what would happen? I can only think it is one of two scenarios.
1. Coolant temp would stay the same
2. Coolant temp would run cooler, perhaps too cool, and would cycle more often. Temp would go over 160 degrees, coolant would get to maybe 170, then it would cool back down below 160 because of cold coolant in radiator.
I've got too much time on my hands, I know. Just curious is all...
Old Oct 2, 2008 | 01:38 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I run a 160deg T-stat year around and, when air is <70deg F, coolant temps run around 160deg.
Old Oct 2, 2008 | 01:58 PM
tequilaboy's Avatar
tequilaboy
During yesterday's drive with similar weather and a 160 degree stat, my ecm internal coolant temp reached 160 degrees after 300 seconds (5 minutes) of running time and remained between 160 and 170 F for the duration of my datalog.
You will run a little cooler with a 160 degree stat, cool weather permitting, or if you run the fan down to low coolant temps.
Old Oct 2, 2008 | 02:13 PM
Corvette Chris
I'm not sure at this point, that I want to change the stat out. I'm quite comfortable with those temps. Even during the middle of summer, the temps were 185-190, which I was very pleased with.
I think I'm going to end up ordering an ALDL cable, and get TunerPro RT over the winter and adjust the fan temp. I think I've got another couple issues I need to look at when I'm in the computer anywho.
Old Oct 2, 2008 | 02:58 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
I am running about like you with a 180* stat. IMO 160* makes no sense in a L98 unless you drag race. It just slows warm ups in cooler months which isn't very efficient. Lowering my fan on temp to 205* helped in the hot summer months.
Old Oct 2, 2008 | 03:07 PM
Corvette Chris
Well, the thing is, I do drag race.
Even so, I still seem to be able to cool the car down fairly easily between rounds. Although I have become fairly religious about icing down the intake between runs. I *may* just try a 160 one night at the track and see if that makes a difference..
Old Oct 2, 2008 | 03:57 PM
65Z01's Avatar
65Z01
It may slow "warm ups" in the cabin but the engine still comes up to 160deg as fast as with a higher temp T-stat. I run my Vette year around (yes, even in snow) and she still gets plenty warm for my comfort.
I find that launching at 160 deg brings more power than a launch at higher coolant temps. I open the A/C pressure connector at the track so the main fan is always running for max cooling. If coolant temp wants to creap up on warmer days, setting the A/C to 90Deg F and turning in On to HEAT helps to hold coolant temp down while waiting to stage up.
Try a copla passes at low and at higher coolant temps and compare trap speeds; I think you will be convinced.
Old Oct 2, 2008 | 04:27 PM
Corvette Chris
I have noticed a difference when I have to hotlap. Its definitely slower when warmer, and like I said, I try to ice down the intake to help bring temps down too. I have a manual fan switch to install, I just haven't gotten around to it. I'm also afraid of killing the battery with it too, though.
What kind of 1/8mi trap speeds/ETs were you getting stock?
To T-Stat Q....
