Anyone else haveing this problem ???
Old Oct 2, 2008 | 07:36 AM
R RUPERTUS's Avatar
R RUPERTUS
Default Anyone else haveing this problem ???
1996 lt1 wont idel down right way. driving along at say 40 mph .. let off gas and it will idle down to about 1200 rpm...and it wil cruse along that that for a long time.... come to a stop and it idles down to 800 rpm... shift to neutral and it seems to idle down like it should. Its almost like a carb with a fast idle/ choke. I have replaced the TPS / IAC / and flue pressure sensor. All cables seem to be working as they should. Really confused on this one.. Thanking you for all you help in advance. R
Old Oct 2, 2008 | 07:40 AM
StealthLT4's Avatar
StealthLT4
Mine does that also. I think it's just supposed to idle higher when in motion than when stopped.
Old Oct 2, 2008 | 07:45 AM
R RUPERTUS's Avatar
R RUPERTUS
i dont remember it ever doing this before, and i dont think it should drive its self up hills....???//???
Old Oct 2, 2008 | 08:28 AM
pcolt94's Avatar
pcolt94
I think you do have a problem. I am familiar with that scenario on other cars where they do hold the idle higher while in motion. When the car stops the idle reduces. I think this functions might be in regard to emissions. But yours sounds like an aggravated condition.
I don’t have an exact answer to the problem but emissions might be a place to start. Look at sensors EGT, solonoid, etc. Look to see if a code is set, you don’t necessary have to have a SEC light come on to have a code set. Have you had a gas mileage change, O2s?
Old Oct 2, 2008 | 09:38 AM
NEVRL8T's Avatar
NEVRL8T
Vacuum leak?
Old Oct 2, 2008 | 10:38 AM
MK 82's Avatar
MK 82
What kind of trans? Unless it is a manual in neutral, the engine is being driven somewhat by the tranny in coast mode.
Old Oct 2, 2008 | 12:16 PM
R RUPERTUS's Avatar
R RUPERTUS
Originally Posted by TheAngelOfDeath
Vacuum leak?
all been checked...tks
Old Oct 2, 2008 | 12:21 PM
R RUPERTUS's Avatar
R RUPERTUS
its an lt1 so its an auto... i understand how that happends , but it should run on and even go up hill on its own... but tks..
Old Oct 2, 2008 | 12:24 PM
R RUPERTUS's Avatar
R RUPERTUS
tks ..dont have any codes set. gas milage has gone down some but that would be due to prolonged high rpm's
Old Oct 2, 2008 | 01:26 PM
conv90's Avatar
conv90
Are you with the lever selector in OD ?
Try with th elever in D
If you let gas at 40 mph you shold feel engine braking -Overrun- .
If In OD It's normal, it's due to iac steps added in motion.
There is a table with steps added vs. speed.
Old Oct 2, 2008 | 02:09 PM
simple green's Avatar
simple green
Have you checked the voltage from the IAC valve and the TPS? With throttle closed the TPS voltage should be 0v - 0.5v and I cant find the voltage for IAC but it should be between 5 - 45 counts on a scanner. You can pull the IAC out and clean it with contact cleaner, sometimes they get gummed up.
Old Oct 2, 2008 | 04:35 PM
ukzo6vette's Avatar
ukzo6vette
Default Fast Idle
Just read your post with interest as I had the same problem for about six months, thought I tried everything until I decided to do the throttle bypass mod, although I have also installed a new BBK throttle body as well the problem is now history, mine is a 1996 CE Coupe.
Old Oct 2, 2008 | 05:01 PM
MK 82's Avatar
MK 82
If I take my LT4 out of gear and coast to a stop the idle stays at about 1000 till I stop. It then returns to about 800. I think this is normal.
Old Oct 2, 2008 | 05:05 PM
formul89's Avatar
formul89
I had a 2004 GTO 6spd that did the same thing.
Old Oct 2, 2008 | 05:19 PM
MK 82's Avatar
MK 82
Damn, Hugh. We have a breakthrough!
To Anyone else haveing this problem ???
