Help !!!!!
Old Oct 3, 2008 | 11:30 PM
mojo92's Avatar
mojo92
Default Help !!!!!
The ones in red don't work...just stopped all at once. The ones in blue still work, the white lights work on both doors just the orange light on the driver door don't. What would make one side work and not the other and how to fix ? I have replaced all the bulbs and still not working HELP!!!!!
Old Oct 3, 2008 | 11:53 PM
RiktorD's Avatar
RiktorD
Check ALL of your fuses...
Old Oct 4, 2008 | 03:54 AM
mechguy79's Avatar
mechguy79
Did you work on something recently? Usually the problem is the last thing you messed with. Could the door have pinch a wire somehow? Oh and I agree the fuses would be the first thing I would go after, and I wouldn't just eye-ball them, I would ohm them out to be sure. Whatever you do, start with the easiest stuff.
Old Oct 4, 2008 | 07:22 AM
Calderone's Avatar
Calderone
Fuses !
Old Oct 4, 2008 | 04:10 PM
mojo92's Avatar
mojo92
Is the passenger side the only place fuses could be on a 91 ?
Old Oct 4, 2008 | 08:45 PM
Ed Ramberger's Avatar
Ed Ramberger
This is the best post I've seen in a while - the picture cracked me up. THANKS!
Old Oct 4, 2008 | 09:42 PM
mojo92's Avatar
mojo92
Your welcome Glad to have made your day
Old Oct 4, 2008 | 10:09 PM
engle1147's Avatar
engle1147
If the fuses check out then check for power.....know that year uses a Body Control Module which controls a bunch of various crap....it could be on the blink. I'd help you out if I could but don't have a book for your year...it might be wise to check to see if those "don't work" components run through the BCM. Yeah I did a double take on the picture scribble too...it's different.
To Help !!!!!
