hypertech cooling switch problem
Old Oct 4, 2008 | 03:36 PM
trashguy's Avatar
trashguy
Default hypertech cooling switch problem
just installed a hypertech cooling fan switch and its installed in the
correct spot (pass side rear head) and its showing all the symptoms
of being installed wrong. the guage shows lo to 299.the installation
manual says it will do that if its installed in the wrong location??
Old Oct 4, 2008 | 03:55 PM
larryfs's Avatar
larryfs
The fan switch (should) goes to the fan relay, not the guage.
Old Oct 4, 2008 | 05:41 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
What year?
Old Oct 4, 2008 | 06:01 PM
trashguy's Avatar
trashguy
early '86
Old Oct 4, 2008 | 10:20 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Was there a sensor already installed in the passenger side?
Do you have the booster fan?
Old Oct 5, 2008 | 08:15 AM
trashguy's Avatar
trashguy
yes and yes
Old Oct 5, 2008 | 08:25 AM
braeburn22's Avatar
braeburn22
Default hypertech switch
the hypertech switch installs in place of the standard switch on the drivers side of the engine towards the front, the temp switch on the rh cylinder head is for the dash temp guage
Old Oct 5, 2008 | 08:26 AM
braeburn22's Avatar
braeburn22
i forgot to mention the sensor is between cylinders 1 and 3
Old Oct 5, 2008 | 09:18 AM
trashguy's Avatar
trashguy
thanks. after reading other responses I think I'll go with a manual on/off switch for the primary fan.
Old Oct 5, 2008 | 11:18 AM
BADDUCK's Avatar
BADDUCK
On my 1989 that switch/sensor is for the aux fan. Maybe your iron heads are different.
Old Oct 5, 2008 | 01:50 PM
65Z01's Avatar
65Z01
Just replace the Aux Fan switch (between #1 & #3 spark plugs) with the new switch and splice into the Grn/Wht wire from that switch to the main fan relay (on inner fender well below brake MC) Grn/Wht wire.
You can get insulation displacement connectors and mating lugs at Radion Shack which will make the connection a piece of cake. I routed the new wire through the large wire bundle running along the LH fender well for a very stealth installation.
Old Oct 6, 2008 | 04:22 PM
trashguy's Avatar
trashguy
thank you. sounds like the way to go
To hypertech cooling switch problem
