brain fart....
Jan 8, 2002 | 10:37 PM
brain fart....
when O2's are going out... does the car run rich or lean.. i can't remember.. :crazy:
I've got lots of rich BLM readings on the blazer and I have a feeling the O2 (s) need replacing.
[Modified by Glock'94, 8:38 PM 1/8/2002]
Jan 8, 2002 | 11:08 PM
Re: brain fart.... (Glock'94)
they are like spark plugs... replace them every 30k or so...
Jan 8, 2002 | 11:09 PM
Re: brain fart.... (bogus)
ya.. i know.. just trying to learn here ;)
Jan 8, 2002 | 11:17 PM
ok... learning... I guess it depends on which way the voltage goes when the O2 goes bad.
From what I remember, most of the time they go rich.
Jan 8, 2002 | 11:20 PM
I just got done doing a 10 minute drive recording everything from the computer... so i've got about 400 cycles of the O2 sensor. It's doing the usual 100-900mv sin wave.
Jan 8, 2002 | 11:21 PM
Car definately goes rich
Jan 8, 2002 | 11:40 PM
Re: brain fart.... (Romeo Barrera)
That's what i thought ;)... thanks.
Jan 9, 2002 | 01:28 AM
Also while you're scanning you'll notice that it gets "lazy". The speed that it switches from rich to lean will slow down.
Jan 9, 2002 | 01:44 AM
<---Brian Fart (Glock)
You will experience HORRIBLE gas mileage. The reason being, when an O2
sensor fails, it fails to rich so it doesn't burn up the engine. you
will also notice knocking at idel, also possible rough ideling.
Jan 9, 2002 | 02:13 AM
Re: brain fart.... (JonM)
Some of these symptoms sound familar. Could this cause high coolant temps?
Jan 9, 2002 | 02:39 AM
:lol: :lol:
The blazer gets about 16-18mpg.. which it's too bad for a 4.3L V6.
I'll go back through the log and see if the cycle of the O2 slows down..
Jan 9, 2002 | 08:51 AM
:yesnod: It goes rich. :yesnod:
