backfires now when letting off gas
If the check valve is bad, it pops n spits.
Also check to see that there's no codes, and that the O2 sensor is still plugged in and the wires are good.
Did you put the exhaust, intake, and chip all in at the same time? I would not rule out the Hypertech chip, but I don't think they affect timing enough to cause a mis-fire. I could be wrong though.
If your '90 is like my '89, there is only one O2 sensor on the driver's side. And, the injectors fire in batch mode (simultaneously) vs sequentially.
If any injector goes bad on the driver's side, the ECM sends more gas to ALL injectors. Because the O2 can only monitor what one group of four injectors are doing, it is forced to ASSUME what every injector is doing. One lean/bad injector on the driver's side lowers the amount of unburnt "fumes" going to the O2 sensor. The ECM can only respond by sending more gas to every injector. Now you have 1 (or more) bad/lean injectors plus up to 7 rich injectors! From that, you can assume at least one of the following will result:
- The good injectors (pumping more gas) cause a rich condition. More fumes are entering a HOT exhaust pipe where they can explode/pop. Additionally, ODB1 computers are "slower" to react. Therefore, I have to assume a slow ECM may not terminate/adjust injector pulses fast enough (on decel) to prevent extra gasoline from entering the exhaust stream. The ECM may be fast enough to minimize outright popping with a factory exhaust -- but not with compensating injectors and an open exhaust system.
- Bad injectors can reach a borderline were a "lean miss" occurs. Not enough fuel enters that cylinder for proper combustion. But, fuel could enter the HOT exhaust pipe where detonation can occur.
The "performance" chip you purchased could "aggravate" the problem by asking the ECM to deliver a richer burn (in addition to a possible injector issue). Again, quieter exhaust systems muffle those types of pops -- making them difficult/impossible to hear. That's how your mods could make it seem like they created a problem that was already there.
the chip was in it , I only changed other things. some times happens if I rev it all the way up period.
so sounds like -no back pressure- timing is to advanced somehow- bad injectors(buying fic)
so you guys think I should retard the timing?
The only time that I have really seen this was on bikes and the fix was to go up on the low speed jets to allow a little more fuel when the throttle was closed. Maybe someone experienced with this issue will chime in to tell you how to richen it up a little when the butterflies are closed. The intake change will probably fix it anyway so I wouldn't stress over it right now, do the intake and then stress
Yep.
