Another new problem ....Third brake light bulbs ....are special ?
Old Oct 5, 2008 | 09:20 PM
Calderone's Avatar
Calderone
Default Another new problem ....Third brake light bulbs ....are special ?
Yesterday i found that one of my 4 bulbs of the third brake light is not working,so i thought i will replace them all.-
Took off the cover and i saw which type of bulbs i saw this :
This are the same used on the sides.-
i took them off and i found out that they were adapted,they put little copper cables as terminals on each end,they ends were bent and they put this copper terminals on it,i try to do the same,and i couldn't.-
I Went to Midamerica site,and find out that the correct bulb is this :
Is this a hard to find bulb ???????
why they adapted the normal bulbs to make them fit there ?
i can't understand that !
i will buy the replacements from Midamerica if i can't find the right ones on the local stores ...
wow...strange ...
Old Oct 5, 2008 | 10:36 PM
Ed Ramberger's Avatar
Ed Ramberger
The correct light that you found is a mini-halogen bulb that usually sells for between 7 and 12 dollars. I would guess the previous owner was cheap and modified a side marker bulb to fit. Your 3rd brake light will be bright like it should be now.
When these burn out it's good to catch them quick and replace them - if you don't replace them the remaining ones tend to have a shorter life.
Old Oct 5, 2008 | 10:39 PM
Calderone's Avatar
Calderone
Yes,i see now,i will buy them asap
thanks !
Old Oct 5, 2008 | 10:52 PM
MrRenoman's Avatar
MrRenoman
NAPA has them if you don't want to order online and pay shipping.
Art
Old Oct 5, 2008 | 10:55 PM
Calderone's Avatar
Calderone
thanks but im located in Chile
No Napa here
Old Oct 6, 2008 | 08:48 PM
Bulldog Steve's Avatar
Bulldog Steve
Go to a home supply store like home depot....
Find the out door low voltage bulbs they are the same and 1/4 the price! They work great.
Steve
Old Oct 6, 2008 | 08:52 PM
Calderone's Avatar
Calderone
Hi Steve
You mean not automotive ?
i was looking today in Homecenter here,and i couldn't find anything similar
but i can look again...which lights are you referring to ?
Old Oct 7, 2008 | 05:03 AM
88yellow's Avatar
88yellow
Steve
I got mine at Radio Shack. Less than 2.00 bucks each.
Old Oct 7, 2008 | 07:53 AM
Calderone's Avatar
Calderone
any number or reference or what kind of bulbs are you talking about ?
Old Oct 7, 2008 | 06:31 PM
rodj's Avatar
rodj
Used in desk lamps
Look in lighting /houseware dept of any big homeware store ,
not auto.
Old Oct 7, 2008 | 06:35 PM
Calderone's Avatar
Calderone
cool,any number reference ?
thanks
Old Oct 7, 2008 | 11:51 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default bulbs
I got mine at home depot for $1.85, and when I went back, they had upped them to $4.99.
Malibu light bulbs. Sure beats the $12 you find at CSK.
Old Oct 8, 2008 | 12:03 AM
Calderone's Avatar
Calderone
Found this ones :
but i thnk 20w is too much ?
Stocks are 8 w
http://www.homedepot.ca/webapp/wcs/s...k=P_PartNumber
Old Oct 9, 2008 | 10:20 AM
Calderone's Avatar
Calderone
UPDATE ! ! !
I got them from a local electric store !!!
Rod was right,those are the same used on desk lamps BUT ........
They are 20W,and there is no lower watt available bulbs .-
What i think is 20W X 4 = 80W
Stock : 8W X 4 = 36W
44 extra watts !
Im afraid to toast something or fry something,i don't want to do that
any help ?
thanks
Old Oct 9, 2008 | 03:08 PM
Calderone's Avatar
Calderone
any ??????????'
Old Oct 9, 2008 | 04:43 PM
Calderone's Avatar
Calderone
Old Oct 9, 2008 | 07:12 PM
Calderone's Avatar
Calderone
To Another new problem ....Third brake light bulbs ....are special ?
Old Oct 9, 2008 | 08:57 PM
Bulldog Steve
Here we have small lights in our yards that run off a D.C. transformer. That you can get at home supply store low voltage type. Malibu lites they are called here. Just made of plastic and are cheap.
Steve
Old Oct 9, 2008 | 09:05 PM
Calderone's Avatar
Calderone
Yes i found them
but 20W is the min
Old Oct 9, 2008 | 10:07 PM
Calderone's Avatar
Calderone
UPDATE ! ! !
44 extra watts !
any help ?
thanks
