Intake Manifold
Old Jan 9, 2002 | 10:32 AM
Jim D's Avatar
Jim D
Default Intake Manifold
I have to change the gaskets on the intake , as I was checking it out last night
the only thing I don't understand is how do you remove the ASR cable from the throttle body , or don't you. Thanks as always for your help Jim
Old Jan 9, 2002 | 01:27 PM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: Intake Manifold (Jim D)
It comes off on the throttle body end just like a normal throttle cable. You kinda have to open the throttle by hand and you'll see there is a slot for the cable to come out of, you'll have to align the cable with the slot and then either push or pull it out. Mine was real tough the first time I had to do it.
