intake question
Old Oct 8, 2008 | 08:50 PM
jtoombs's Avatar
jtoombs
Default intake question
im thinking about buying the big mouth intake from tpis and i was wondering if its a hard swap, how will EGR be affected, and what kind of hp gains am i looking for with stock runners and also with SLP runners ( or ported )
Old Oct 8, 2008 | 09:03 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If thst is the hi-flow base and LT runners you could expect to see around 15chp gain.
Old Oct 9, 2008 | 10:18 AM
braeburn22's Avatar
braeburn22
Default big mouth and slp runners
hi
I just installed the edelbrock hi flo and slp runners, took about 5 hours, but because the slp runers have a thicker flange and are generally larger, it was quite awkward with the fuel rails, and only use the standard intake bolts between the intake and the heads as ARP ones foul the runners slightly.
Mark
To intake question
