Help me? changed shifter but how do u wire it???
I replaced the shifter with a b@m megashifter an noticed the electronic switch on the stock shifter.
? How do u bypass this an wire it to make the car start an stop?
1) Did you adjust the cable down at the tranny..if not; it will throw the position of gear select out of whack.
2) Did you get the extra switch from Radio Shack as suggested in the instructions...not supplied with the kit.(car will start in any gear without it)
3)Have you adjusted the 2 micro switches that are bolted together...had a heck of a time in that if not adjusted properly to the shifter; my back up lites stayed on..had to wiggle the shifter to disengage ...when I readjusted the micro switch to rid the problem; the shifter had to be moved just slightly back in the park position for car to start. It took a bit to adjust both problems out.
This is all I can think of now...its been quite a while ago.
http://www.iroczone.com/projshifter01.htm
