30mm front sway bar bushing help
Old Oct 10, 2008 | 03:28 AM
zz90vette's Avatar
zz90vette
Default 30mm front sway bar bushing help
iam installing polygraphite bushings on my 90 front sway bar, i got the bushings from private party W/ no instructions so do you leave the metal sleeve on the sway bar end, & push out the rubber inside, & push back in the new poly bushing, thanks
Old Oct 10, 2008 | 03:02 PM
BlackHarleyMan's Avatar
BlackHarleyMan
You'll need to press out the bushing and metal sleeve, and then replace it with the new poly bushing and new sleeve. IF your new set did not come with a new sleeve, then you'll need to reuse the old one.
R/Noland
P.S. Make sure you lube it up real good with some marine grade grease or whatever you may have gotten with your setup!
