I have similar issues. If I give it enough gas to accelerate but not drop into Drive from Overdirve there is an awful noise from somewhere. It doesn't have to be above 60 mph either. I can't pin it down. Thought it may be a exhaust rattle but noting seems to be loose.
No response yet. The shudder happens only at part throttle over 60mph. More throttle, less shudder.
I've got a similar problem. When I'm in OD and when I get right at 70mph, when I hit the throttle I get a shudder that comes from the engine.
I'm gonna add some of that Dr. Tranny anti-shudder. I think it is made by Lubegard.
By the way, which should one get: LUBEGARD ATF Protectant (Red bottle) or LUBEGARD Highly Friction Modified-ATF Supplement (Black bottle)? Why would one need the friction modifier?
