Thinking about Hooker super comp
Old Oct 10, 2008 | 08:06 PM
snowmanmdp's Avatar
snowmanmdp
Default Thinking about Hooker super comp
I have an 85 and am thinking about getting a set of Super Comp. Header
Part #: 2151-1HKR
Anyone have these and what do you think? How do they fit?
Thanks, Mike
Old Oct 10, 2008 | 08:59 PM
C409's Avatar
C409
Very easy to install....excellent performance....I believe only one tube has a weld if any....my only change was to install a bung in the collector for the O2S.....Hooker puts it in the #7 tube and it will react to that cylinder only if you leave it that way
Old Oct 10, 2008 | 10:45 PM
snowmanmdp's Avatar
snowmanmdp
Any chance you have a picture of how they look installed? My motor is just about all stock, a little plenum and runner porting and and cut airbox.
Old Oct 11, 2008 | 09:55 AM
mseven's Avatar
mseven
I have a few pics. in "my corvette photos".
Old Oct 11, 2008 | 10:41 AM
snowmanmdp's Avatar
snowmanmdp
Thanks....easy install and fit nice also?
Old Oct 11, 2008 | 01:35 PM
ultraviolet70's Avatar
ultraviolet70
Couple pics for ya
Old Oct 11, 2008 | 03:33 PM
snowmanmdp's Avatar
snowmanmdp
Thanks guys
Old Oct 11, 2008 | 03:48 PM
vader86's Avatar
vader86
2151s come with no emissions provisions and no O2 bung, and are uncoated. You will need the coating and the O2 bung put in beforehand.
Old Oct 12, 2008 | 02:02 AM
ultraviolet70
Actually 2151s can be ordered with or without ceramic coating, and they do come with an O2 bung, but it's in the #7 primary so it's only sampling one cylinder.
Old Oct 12, 2008 | 11:14 PM
pipe's Avatar
pipe
Hmmm my 2151s didn't come with the O2 sensor bung welded in. Also the Ceramic Coating from Hooker flaked off really quickly. See if ya can buy em without the coating and get em done somewhere. Other than that they fit and installed well. You will have to fab up an Alternator support bracket to brace the alternator from the rear.Pipe
Old Oct 12, 2008 | 11:36 PM
mseven's Avatar
mseven
yes, in fact you can put the drivers side in from the top. They used to be available w/no ceramic and have no 02 bung. I just looked at summit and they only show a ceramic coat version now.
*haven't looked in a while but, jet coating was offering them w/coat of choice and the 02 welded in for about the same money*
Old Oct 13, 2008 | 12:06 PM
ultraviolet70
Once again the 2151's DO have an O2 bung in the #7 primary as you can see in this pic
I just put a plug in because I installed my O2 in m collector which is what I suggest, but the headers do come with a bung and could be used if someone chose to. And for what it's worth I think the coating from Hooker is actually pretty nice (take a look at the pics I've posted).
Old Oct 13, 2008 | 08:36 PM
snowmanmdp's Avatar
snowmanmdp
Nice pics guys!
Old Oct 13, 2008 | 09:02 PM
Steve85's Avatar
Steve85
Cruise-In V Veteran
I went with the no emissions with O2 and the #7 primary location sent my wideband O2 off the charts after about 10 minutes of running.
So this project followed...
Original location
Drilled hole in collector
Weld in bung. Get one from auto parts store, the one hooker sent, albeit free, was junk and I didn't use it.
Paint to match. Glad I didn't go with ceramic...
Old Oct 13, 2008 | 09:34 PM
CFI-EFI's Avatar
CFI-EFI
Hooker 2151 headers are painted. Hooker 2151-1 headers are ceramic coated. Both, plus the 2149s, with full smog hookups, have 1 3/4" primary tubes. Headers with smaller primaries, especially with a mild 350 engine, will start to "work", provide more torque at a lower rpm with no sacrifice in the higher rpm power.
RACE ON!!!
Old Oct 14, 2008 | 12:45 AM
383vett's Avatar
383vett
I am also running the 1 3/4 Hooker Super comps on my 406 bracket car. I moved O2 bung to the collector and plugged the #7 bung. Interesting to note that at Infineon Wed nite drags where mufflers are required (115 db max) I run a y pipe; 3" in diameter after the collectors and a 3 1/2" Y. The exhaust is open after that. The noise cancellation of the y pipe quiets the car enough to pass the noise requirements and probably increases torque too. Good enough for 10.58@125
Old Oct 15, 2008 | 07:11 PM
snowmanmdp's Avatar
snowmanmdp
O.K. now the big question, having put headers on everything but a vette, how long is this going to take? Ballpark
To Thinking about Hooker super comp
Old May 9, 2015 | 09:37 PM
BIRDMANmx5's Avatar
BIRDMANmx5
Default install time
DEPENDS
Old May 9, 2015 | 09:38 PM
BIRDMANmx5's Avatar
BIRDMANmx5
Default Install time
Took me 6 hrs but i am not a technician.
Old May 9, 2015 | 09:44 PM
383vett's Avatar
383vett
The op has had 7 years. I think they're on now
