compression ratio
Old Oct 14, 2008 | 07:53 AM
apache84's Avatar
apache84
Default compression ratio
Hi guys,Can somebody tell me what a realistic comp ratio would be for a 1984 Corvette with crossfire injection,& std computer.I'm in the process of rebuilding my engineand need to know your thoughts.
The engine has flat top hyper pistons,crane 2040 cam,alloy heads with 64cc chambers
I will always run it on 94 octane fuel
Old Oct 14, 2008 | 10:15 AM
bjankuski's Avatar
bjankuski
10.5 to 1 with alum heads is about as high as you should go. If you enjoy caculations, you can determine what static compression ratio gives you 8 to 1 dynamic compression ratio. That would be the number I would shoot for. Look up dymanic comprsion ratio and how to caculate it.
