hmm...code 44?
I was just hoping the symptoms would give somebody a lightbulb over the head type moment, but I guess not.
still happening! same symptoms as before:
-rough idle/stalling when cold, occasionally dies when warm.
-Instant mpg goes way down randomly but everything else in normal, then, CEL lights up and engine pics up ~150 rpms on its own and gas mileage gets better, not normal though. After a few cycles or so...car returns to normal, mpg is normal, CEL off, car still running good. If I stop after the car has one of these "episodes", the idle is very smooth and the car is running flawlessly.
-Only code is a 44....lean exhaust present.
Please, someone shed some light!
The rough idle/stalling when cold is a given, happens everyday. Problem gets better as coolant temps rise. When at normal operating temps, car is running smooth, normally....a little glitch at idle here and there, nothing major.
I ohmed out the new CTS, it checks out. the connector is good. I traced all the wiring and found no breaks. O2 is new, everything looks good there.
Here's a rundown of parts replaced or known good for you guys: its long:
Fuel Pump, Fuel Injectors, IAC, TPS, O2, EST module, Timing, MAF sensor, MAF burnoff module, Fuel pressure at rail at all times, CTS, air filter, etc.
Engine (intake, heads, cam, block) all are just 2 1/2 years old. Chip tune by TPIS is dead on. Idle problem started 6 months ago, new problem started 3 weeks ago.
Oh, the car is running very rich btw. Black smoke from the pipes when I rev it up, and smells like a gas station out back. I'm really starting to think something isn't right with the spark system, just don't know what it could be.
WHY!?
However, the ecm is a reman unit from napa, and appears to be at least 8 years old.
Also, if a car is running pig rich, will retarding the timing help? If so, that could be why unplugging the est makes the car run better.
As far as the EST goes, I'm not quite sure as far as your question goes, but I think it would be the opposite. And here's another thing, the last item mentioned once again in the TS tree is a faulty ECM if a code 42 is set.
Do you have a scanner?
