hmm...code 44?
Old Oct 15, 2008 | 04:02 PM
cwyates4's Avatar
cwyates4
Default hmm...code 44?
Still havent got anywhere on this! No one seems to have a clue! please take a look at my newest post.
Today while cruising, the check engine light came on and my instantanious gas mileage dropped to ~8mpg. It stayed like this for a minute or so, then returned to normal for the rest of the 80 miles. Checked codes, came up with a 44...which means lean exhaust present. It said to check the o2 sensor and fuel pressure, both are fine, everything in the fuel system is new, and I have tested many times. The o2 is new also. It also happened while in open loop, I had just started driving, so thats confusing also. Any ideas out there? TPS checks out ok, but maybe its bad....or what about the computer?
I'm lost.
Old Oct 15, 2008 | 05:04 PM
MK 82's Avatar
MK 82
Clear the code and see if it comes back. I never get excited about momentary problems unless they recur.
Old Oct 15, 2008 | 05:57 PM
cwyates4's Avatar
cwyates4
Actually, i had the same thing happen to me last thursday morning...that time, it wasn't during open loop though. I had been cruising for a good 45 minutes.
The only symptoms I feel, is that when the CEL lights up, the car actually feels like its running slightly smoother and has more power. Everything else is normal except the light, and horrible gas mileage.
Here's what I think: I think the TPS is sending false readouts to the computer, like saying we are at half throttle or more. The tps position is what the dash uses to do MPG. So, the computer is seeing half throttle, but the o2 isn't agreeing, its readings are too "lean" for supposedly half peddle. Anyone follow me here?
But...I have tested the tps on many occasions...it reads at .54 at idle, 4.5 at WOT, and the volts rise smoothly as I open the throttle.
Old Oct 15, 2008 | 10:14 PM
cwyates4's Avatar
cwyates4
quick bump...really need some ideas here, gotta make another drive tomorrow, friday, and sunday.
Old Oct 15, 2008 | 10:22 PM
MK 82's Avatar
MK 82
I think your logic is faulty.
Old Oct 16, 2008 | 01:18 AM
lltrevino's Avatar
lltrevino
You have headers, right? Any chance your o2 cooling off? do you have a heated o2 sensor?
Old Oct 16, 2008 | 07:19 AM
cwyates4's Avatar
cwyates4
yes...and no heated o2. But, this is a new problem, just started happening and has only happened twice. Just drove another 80 miles right now and all was normal.
Old Oct 16, 2008 | 08:53 AM
dlb435's Avatar
dlb435
Factory manual says to check the EGR....you do that yet?
Old Oct 16, 2008 | 09:43 AM
loaded vet's Avatar
loaded vet
I had the same thing happen to my 87. It was one of those on again and off again things. After checking everything out I went to the oxygen sensor circuit. I found .00021 volts on the circuit. There is supposed to be .34 volts on the circuit with the key on engine off. I replaced the circuit, measured again and did have .39 volts to the oxygen sensor. No more codes. I don't know what year your Vet is, however, the oxygen sensor does need a reference voltage. It is a easy check to make. I never did like the way the engineers routed the wiring harness over the back of the engine.
Gary
Old Oct 16, 2008 | 11:21 AM
cwyates4's Avatar
cwyates4
Thanks for the pointer there Gary, I'll look into that.
No egr, car has a miniram. thanks though.
Old Oct 17, 2008 | 12:03 PM
cwyates4's Avatar
cwyates4
Did it again today thirty miles into my trip. RPMs rise ~150 and engine smooths out when the CEL comes on. Happened for about two minutes and returned to normal. Thoughts?? Only code is a 44.
Old Oct 17, 2008 | 12:35 PM
aklim's Avatar
aklim
Do you have a scantool to see what the O2 sensor is doing? It might be falling off because it is too cold to operate. I would go with a heated 02 sensor though.
Old Oct 17, 2008 | 01:18 PM
rick lambert's Avatar
rick lambert
Just a crazy thought, but have you checked out your CTS?
Old Oct 17, 2008 | 03:20 PM
cwyates4's Avatar
cwyates4
CTS is new.
No i dont and i do need a heated O2, but i dont think that the car is going between open and closed loop.
Old Oct 17, 2008 | 03:50 PM
aklim's Avatar
aklim
Before you can tell what is going on, you are going to need a scanner. If you were close enough, I could lend you mine.
Old Oct 17, 2008 | 05:07 PM
cwyates4's Avatar
cwyates4
Can I plug a tech 1 in and use it while driving? I'm not sure, but does the tech 1 read aldl info, such as iac counts, tps voltage, etc.?
What doesn't make sense to me is...why the drop in gas mileage...but a lean exhaust code is thrown...that makes no sense at all! When it is acting up, and the cel isnt on, the mpg goes down to 8, then when the cel lights, it rises to 12, and the engine surges just a little.
Other than that, the only problem I'm having with the car is a rough idle/stalling when I first start it up in the morning, or after its been sitting for longer than 6 hours or so.
Could it just be the dang computer!!??
Old Oct 17, 2008 | 05:14 PM
aklim's Avatar
aklim
I think you can use the Tech One for live data gathering, IIRC.
As to the gas mileage, I wouldn't believe it for a second. On my Ford Excursion diesel, other board members call it the "Lie-O-Meter" for a reason. Currently, my car is looking at 40 mpg if that thing is to be believed.
Have you checked fuel pressure and spark?
To hmm...code 44?
Old Oct 17, 2008 | 08:03 PM
cwyates4's Avatar
cwyates4
yes on fp, no on spark. But on the mpg thing, It normally reads 22mpg, but plummets when this problem is happening, then returns when it goes away...it has a significance, whether the mpg is actually true or not. That is why I think its the computer, or the tps. but who knows?
Old Oct 17, 2008 | 09:06 PM
rick lambert
that's a little more info. have you ohmed the injectors?
Old Oct 17, 2008 | 10:08 PM
cwyates4's Avatar
cwyates4
Injectors are brand new from Jon. I would list everything that is new, but I don't want to, the list would be way too big for there to still be a problem.
