Ujoints/87 vert
Old Oct 15, 2008 | 05:50 PM
Jim D's Avatar
Jim D
Default Ujoints/87 vert
Do I have to pull the exhaust off to replace the u joints. How about the half shafts, anything I should know, thanks Jim.
Old Oct 15, 2008 | 07:42 PM
cmontel727's Avatar
cmontel727
For the drive shaft you will have to drop the exhaust. You will not be able to get the shaft completely out. On mine I was able to leave the c-beam in place.
For the half shafts the exhaust can stay. Just have to loosen some suspension parts. IIRC the lower shock bolt and the lower link bar on the knuckle. Also the outer tie rod end has to come loose and the spring tension nut has to come off.
Hope this helps
Old Oct 15, 2008 | 08:35 PM
86PACER's Avatar
86PACER
http://personal.tmlp.com/scorp/vette/images/ujoints/
Old Oct 15, 2008 | 09:10 PM
Matatk's Avatar
Matatk
That's a great reference page!
Matthew
To Ujoints/87 vert
